Getting EGR Code on 90 model. PCV Maybe?
Old Dec 17, 2009 | 02:02 PM
motorjunkie's Avatar
motorjunkie
Default Getting EGR Code on 90 model. PCV Maybe?
We are getting an EGR check engine code on a 90 model.. Is it possible that a stopped up PCV valve could cause this? Or does this def mean the EGR valve is bad? I was thinking a vacuum leak could also be the culprit.. The code is intermittent. Fuel mileage seems low @ 21-22. All highway 60mph Baby footing it.
Old Dec 17, 2009 | 02:38 PM
WW7's Avatar
WW7
What code are you getting? PCV valve can be checked easy, shake it , if it rattles its ok...
Old Dec 17, 2009 | 04:07 PM
j-wireman's Avatar
j-wireman
I agree with WW7. If it rattles, it's good. I'd just go ahead and replace the EGR (I don't know of a way to test the EGR valve). Then erase the codes. Run it and see if it shows the EGR code, again. I would think a "bad EGR valve" would affect gas mileage. It's part of the pollution control system.
Use TWO wrenches on the EGR.
Old Dec 17, 2009 | 05:51 PM
gmboileau's Avatar
gmboileau
Before replacing any parts verify the code and do a diagnosis to isolate the problem part.
If it is Code 32 it is associated with the whole EGR circuit not just the valve.
Code 32 could be
-EGR valve
-EGR solenoid
-the vacuum lines to in the EGR circuit
-the wiring to the EGR solenoid
-the park neutral switch
There are test procedures in the FSM to help isolate the problem.
Old Dec 20, 2009 | 04:11 PM
j-wireman's Avatar
j-wireman
gmboileau is right. There is more to it than just the EGR valve. That was the first thing I thought of. So, that came out of my mouth and a slice of "humble pie" replaced it. He's right.
Old Dec 20, 2009 | 05:32 PM
motorjunkie
Thanks for the suggestions.
It also appears that the thermostat is bad. THe car will not get above 150 deg. I think that could also affect the mileage.
Old Dec 20, 2009 | 06:42 PM
rodj's Avatar
rodj
Originally Posted by motorjunkie
We are getting an EGR check engine code Is it possible that a stopped up PCV valve could cause this?
PCV has no relation to EGR.Two seperate systems
EGR operation is controlled by the computer ; PCV works all the time by engine vac
If engine is not getting to correct temp then it will affect lots of things as many engine functions are heat sensitive ; there are settings that turn on / off dependent apon engine temp
Old Dec 20, 2009 | 07:33 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
The EGR, so I have read, is a trouble spot with the 90. As a matter of fact I just read that today, but don't recall where.
but go with a whole diagnosis as stated above and don't just assume it's the EGR valve itself.
Old Dec 20, 2009 | 09:15 PM
gmboileau's Avatar
gmboileau
[QUOTE=rodj;1572487627
If engine is not getting to correct temp then it will affect lots of things as many engine functions are heat sensitive ; there are settings that turn on / off dependent apon engine temp[/QUOTE]
To Getting EGR Code on 90 model. PCV Maybe?
