Jet program chip/module 19616
Old Dec 17, 2009 | 04:43 PM
split-end's Avatar
split-end
Default Jet program chip/module 19616
I have a 1996 LT1 automatic CE and I was thinking of installing a Jet program chip # 19616. Does anyone have this type chip/module installed in their Corvette? If so, is it worth buying/installing? Do these type of chip/modules work? Jet shows a dyno sheet of a LT1 Camaro with HP increases of up to 22+ HP gain.
Old Dec 17, 2009 | 05:07 PM
mike100's Avatar
mike100
Wouldn't a 96 have a flash RAM...I don't think the 'chips' are removable on the last couple of years of vette (I don't know for sure though).
I've heard mixed reviews...they are a nice upgrade to auto transmission cars more than manual ones, typically. I had one for a 92 Z-28..could not tell the difference, but the chip pinged too much when I got a supercharger, so I suspect it was mostly an ign timing mod.
Old Dec 17, 2009 | 07:24 PM
split-end's Avatar
split-end
The Jet module I am looking at is like an adapter where you remove the listed cable going into the EMU (I think), then insert the module in its place and them plug the cable back into the Jet Module.
Old Dec 17, 2009 | 07:32 PM
pr0zac's Avatar
pr0zac
why not just get lt1 edit for the same price?
Old Dec 17, 2009 | 07:48 PM
mike100's Avatar
mike100
piggy backs suck, especially since the 1994-1996 ECM's are a little more advanced and easy to reprogram. The only real use for the piggy back is trying to be stealth with a warranty, but that obviously isn't an issue anymore.
Old Dec 18, 2009 | 03:25 PM
split-end's Avatar
split-end
pr0zac, what is a lt1 edit and what does it do?
Old Dec 18, 2009 | 03:38 PM
pr0zac's Avatar
pr0zac
a program that allows you to tune your pcm.
Old Dec 18, 2009 | 07:57 PM
split-end's Avatar
split-end
Pr0zac, what is the name of this LT1 edit and where can I get. What kind of HP can I expect to get using the LT1 edit?
Old Dec 18, 2009 | 07:59 PM
pr0zac's Avatar
pr0zac
http://carputing.tripod.com/9697lt1edit.htm
Old Dec 18, 2009 | 09:57 PM
split-end's Avatar
split-end
Pr0zac, thanks for the information but, after looking at the program it looks too complicated for me. It looks like the program requires much more knowledge about computers and car management than I have.
To Jet program chip/module 19616
