LT1 head gasket ?
Old Dec 17, 2009 | 06:22 PM
surfer93's Avatar
surfer93
Default LT1 head gasket ?
I need new head gaskets and I went to Autozone and now I have questions.
1) There are 18 different head gaskets from $22 to $85, what is the difference between MLS bore bead combustion seal and Copperwire combustion seal?
2) What does "Minimal brinelling of aluminum heads" mean?
3) what does "Stainless steel core laminate construction" mean?
This is a stock engine that I am going to polish the heads, while there off.
Also, is it really necessary to replace the head bolts?
Thanks in Advance!!
Old Dec 17, 2009 | 07:07 PM
STL94LT1's Avatar
STL94LT1
Here's a high quality, cheap head gasket that will increase your compression and give you a little more horsepower.
http://www.cnc-motorsports.com/product.asp?ProdID=20111
Old Dec 17, 2009 | 07:09 PM
pr0zac's Avatar
pr0zac
+1 on those.
Old Dec 17, 2009 | 08:00 PM
tblt44's Avatar
tblt44
What kind of HP increase are we talking about? I would guess 5 hp.
What kind of compresion should you expect with those?
Old Dec 17, 2009 | 08:01 PM
pr0zac's Avatar
pr0zac
on a stock lt1 right about 11:1. i don't think it will be a significant gain in hp but it will make your quench better.
Old Dec 17, 2009 | 08:04 PM
94z07fx3's Avatar
94z07fx3
IMO
GM Headgasket is just fine 10168457 $30
And yes. TTY bolts should be replaced.
ARP 134-3701 head bolts $70
Old Dec 17, 2009 | 08:13 PM
pr0zac's Avatar
pr0zac
Originally Posted by 94z07fx3
IMO
Composition gasket for LT1/LT4 engines.
Compressed thickness is 0.050".
that and the piston .035 in the hole makes for a fanastic quench. although the gm gasket is a quality gasket its not ideal. if you are that hung up get an impala gasket. they are .028 compressed thickness.
Old Dec 17, 2009 | 08:17 PM
94z07fx3's Avatar
94z07fx3
Would you advise the use of copper spray for gaskets that were meant for iron blocks with iron heads? (when used with aluminum heads on an iron block)
Old Dec 17, 2009 | 08:19 PM
surfer93's Avatar
surfer93
These say for 4.010, I thought stock was 4.000?
Old Dec 17, 2009 | 08:20 PM
surfer93's Avatar
surfer93
IMO
TTY bolts?
Are they the head bolts?
Old Dec 17, 2009 | 08:22 PM
STL94LT1's Avatar
STL94LT1
No!!
Old Dec 17, 2009 | 08:43 PM
pr0zac's Avatar
pr0zac
all head gaskets need to be larger then the bore for proper sealing.
Old Dec 17, 2009 | 08:44 PM
pr0zac's Avatar
pr0zac
is this a smart *** remark? if so you're a moron.
Old Dec 17, 2009 | 08:46 PM
pr0zac's Avatar
pr0zac
TTY bolts?
torque to yield. yes the head bolts
Old Dec 17, 2009 | 08:48 PM
aboatguy's Avatar
aboatguy
+1 on those.
Thats what I use on my impala....good gaskets
Old Dec 17, 2009 | 08:49 PM
pr0zac's Avatar
pr0zac
its a 4.1 inch bore for that gasket BTW..
Old Dec 17, 2009 | 08:50 PM
94z07fx3's Avatar
94z07fx3
I've read contradicting advise. I asked a question. It was not a remark.
Questions end with these "?"
Remarks end with these "."
If you didn't know that you're...
Why the name calling bull**** for a simple question?
To LT1 head gasket ?
Old Dec 17, 2009 | 09:05 PM
94z07fx3's Avatar
94z07fx3
so when you are talking to someone you quote yourself? <--question, but also a hair of sarcasm.
I now know exactly what weight to assign to your comments. Don't worry I won't see them anymore.
pr0zac's Avatar
pr0zac
i know the difference. thanks.. i also asked a question.. and the remark depended on the answer.. if you didn't know that then you're..
Old Dec 17, 2009 | 09:06 PM
pr0zac's Avatar
pr0zac
i don't know how i will sleep at night.
