I checked everything and here is what I found:
1) Valve cover was tight but I noticed oil toward the backside of the cover.
2) Oil pan was moist but not the source of the leak.
3) Oil pressure switch was dry.
4) No obvious leak from the intake.
5) PCV valve functioning but changed it anyways.
6) Tracked the oil on the valve cover to a loose crankcase ventilation tube; put some teflon tape on it and shoved back in, put a hose clamp on the other end.
The smoking stopped and I think the loose ventilation tube was the major contributor but I will keep inspecting it.
From what you're describing it sounds as if you may have blowby pushing oil out of the valve cover openings. Is the oil on the top of the cover running down or does the oil show under the cover? If it's more on top then your rings are worn bad enough that you are getting blowby.
You are probably right, this LT1 has led a hard life; it has got over 100 track hour of usage and it still pulls pretty good! The blowby could of blown the crankcase ventilation tube off, the oil pooled on the top of the intake manifold and leaked down the rear side. That is not to say that is the only leak but the one I observed.
Hopefully, I will be able to put this fix to the test this Sunday and give it another 2 hours of track time at Thunderhill; I will do my best to maximize the blowby
Mine is burning oil too, seems to be only at back! thinking the manifold or oil sender thing!
but now that i remember my valve(forgot the name- middle of inlet manifold) is not connected! this can cause crankcase pressure right?
Can i just hook up a vacuum line to it? as the black plastic connector that routes the vacuum hose to it from the vacuum ball near front left light, is broken! :s
What is the purpose of this black connector! why not just connect vacuum straight to the valve?
thanks
