1993 Interior Lighting Problem
Old Dec 17, 2009 | 11:23 PM
BryA's Avatar
BryA
Default 1993 Interior Lighting Problem
Hi All - this is my first post on the forum, I have mostly been viewing, but it is time for a request for some help!
I have a 1993 LT1, and I have a battery drain issue. The car battery will not last overnight and I have diagnosed it so far to be something from the 20amp Interior Lighting Maxi Fuse under the hood, in the block in front of the Battery. From there I am stuck. I can pull the interior fuse (passenger side door) RH Courtesy and LH Courtesy, but I am not getting the same load difference as pulling just the single Maxi Fuse under the hood.
What circuts run off the Interior Lighting Fuse Under the Hood? I have checked the bulbs, and the lights seem to go off inside the car.
One extra bit of info - The power antenna was replaced a while ago with an aftermarket unit (gotta switch that!!). Is this on the same circut?
Cheers! All help is appreciated!
Old Dec 18, 2009 | 01:16 AM
jhammons01's Avatar
jhammons01
I'll guess headlights motors....Try unhooking the plugs to the headlight motors and see what happens
Just a guess.
Old Dec 18, 2009 | 04:11 AM
toptechx6's Avatar
toptechx6
In addition to the RH Courtesy and LH Courtesy fuses, the 20 AMP Maxi fuse also powers the following 5 amp fuses, RH Illumination and LH Illumination, LCD fuse, CCM#2 fuse, RDO batt fuse, and console illumination.
Old Dec 18, 2009 | 07:26 AM
BryA's Avatar
BryA
Awesome - So I am going to try all of those. Can I assume that pulling these fuses, I should see the same impact on my test light? (I have the Negative battery cable disconnected, and the test light in series between the terminal and the cable). When I pulled the 20amp MAXI that light would DIM...
Old Dec 25, 2012 | 04:47 PM
ndyhathaway's Avatar
ndyhathaway
1st Gear
I'm having this exact problem. Did you find the culprit?
To 1993 Interior Lighting Problem
