Need help converting from carb back to TPI
I picked up a TPI set up and luckily enough the previous owner had left the wiring on the vette. The car will try to start for a second or two but will not stay running.
Here is what I have done so far.
1. Verified spark was good.
2. Verified ground straps are connected.
3. Verified all fuses good in the fuse panel located inside the car.
4. Jumped diagnostic plug with paper clip but it just kept flashing code 12
5. Replaced the control module in the distributor
This is my first TPI setup so I am in unfamiliar territory. I have a Chilton manual and an ohm meter along with various other tools.
I have discovered that the following are missing and do no t know if they would keep the car from starting:
1. Knock sensor
2. EGR solenoid
3. Air diverter valve
4. Air select valve
the original 700r4 transmission has also been swapped out for one that is not computer controlled.
I also pulled the ECM out and opened it up just too see if there was any burned areas in the circuit board and everything looked fine.
From what I have read the ECM performs checks with various sensor to see if it needs to keep the fuel pump on. If some of the "checks" it looking for are not present then the fuel pump will not stay on.
I think there is something called a noid to check to see if the injectors are getting any current or signal from the ECM. I can't seem to find one locally but I think I can make something from a light bulb to work.
Thanks for the replies so far keep the suggestions coming.
I rigged up a test light and verified that the fuel injector plugs are getting a pulse when trying to crank the car.
After trying for several minutes of off and on cranking I pulled a couple of plugs and could see fuel on them.
Out of frustration I pulled the air filter tube off the throttle body and shot some starter fluid in. My wife was helping me by sitting in the car and turning the key. Still the same thing it would try and start for a split second. For no logical reason I flipped the throttle a couple of times and bam the car started. It continued to run as long as I kept opening the throttle but would try and die if I let off.
It finally died and the battery was too dead to start it anymore so I am letting it set with the battery charger.
Big question is what now?
Mine was a wiring botch job, and short of a $1000 replacement loom etc it wasn't going to happen.
But the factory service manual is invaluable, yea Its a $100 dollars for a photocopied service manual but it will make your life Much easier..
I am also getting a code 42 now. This is "Electronic Spark Timing (EST) circuit grounded or Ignition Control (IC) circuit grounded or faulty bypass line.
I have not checked the actual fuel pressure yet only verified that it is getting fuel pressure.
And just a recap the car will start now as long as I crack the throttle open and if I keep feather it, the car will continue to run. I does however run extremely rough. It also get the code 42 now.
http://members.shaw.ca/corvette86/Code%2022.pdf
Code 42 code be as simple as the timing bypass connector being unplugged. Single tan wire with black stripe, the connector should be beside booster(engine side).
http://members.shaw.ca/corvette86/Code%2042.pdf
(I know you already did some of this)
Check spark, make sure it is able to jump 3/4" and continue for several revolutions.
if that checks, 2nd (as noted) check the fuel pressure. on a TBI system low pressure will make one act like it's flooding and roll black smoke.
If the pressure is 40-45 lbs.
Get a noid light like you said make sure the injectors stay firing for several revolutions.
if they do not fire at all you need to be checking your fuses and relays.
if they fire then stop look into the fuel pump/oil pressure safety circuit (as already noted)
if they do fire for several revolutions check for bad gas. this new gas they are selling now seems to have no shelf life. The vette in my avatar had this very problem (and did exactly as you say, fouled plugs try to start but no go), bad gas, I had to drain the tank and flush the lines, it fired right up.
OK apparently I had a brain fart. I had been checking the resistance on the TPS rather than the voltage. Checked it the correct way and it shows .53v with the connector plugged up. I can roll the throttle and the voltage goes up.
It also seems that the battery is loosing its charge. I am going to recharge it and see if looses the charge with it disconnected from the car. If it doesn't I will connect it and let it sit and check whether it discharges once hooked up to the car.
