new ideal???
Old Dec 18, 2009 | 09:46 PM
bacord's Avatar
bacord
Default new ideal???
I just bought a 95 lt1 and was thinking about doing the TB by-pass. Could I just take the hose from the radiator and connect it to the metal part of the hose by the valve cover and get rid of the 3" to 4" rubber hose and not use the by-pass coupling?? I figure it would be 2 less clamps to go bad. Has anyone done this???
Old Dec 19, 2009 | 08:38 AM
STL94LT1's Avatar
STL94LT1
That's what I did on my friends 95 LT1 TA several years ago, and no problems occured.
Old Dec 19, 2009 | 09:37 AM
tblt44's Avatar
tblt44
Pictures please I'm new to the vette world 4 months now and have a 95 and would consider doing this also.
What is the benifit????
Whare are you talking about?
Old Dec 19, 2009 | 09:55 AM
aboatguy's Avatar
aboatguy
Mines been like that for more than 5 years with NO PROBLEMS. However, don't expect any seat of the pants improvements.
Old Dec 19, 2009 | 10:02 AM
aboatguy's Avatar
aboatguy
On a 95 there is a little rubber elbow connecting the steam pipe to the throttlebody and on the other side there is a rubber hose that goes to a t on passenger side of the radiator. Pics should not be needed.
Just remove coolantl hose from passenger side of Thottle body ...remove the elbow from the steam tube and install coolant hose from passenger side on to the steam tube. (this will remove the coolant flow from the Tbody. Some say it will improve horsepower .. I did the mod IOT make removing the TB easier. If you live in cool humid areas I'd leave it since GM did it IOT stop TB icing. I did not experience TB icing even in stupid cold weather in Colorado Springs since the air is so dry.
I want to reiterate I believe this is pretty much useless as a performance mod however, as OP remarked it helps remove a couple of hoseclamps and a rubber elbow.
Old Dec 19, 2009 | 10:17 AM
aminnich's Avatar
aminnich
In this picture you can see the coolant hose going over the top of the AC accumalator and to the steam pipe (metal pipe) at the front of the passenger side fuel rail cover. It does get rid of a short hose and two clamps, so maybe a few less places to leak. Performance gains, if any, are very, very minimal.
Old Dec 19, 2009 | 10:58 AM
mike100's Avatar
mike100
I would have tried a mod like that in the past to eek out any possible hp gain, but I like to try to look stock for the smog ****'s- especially on a car that is within 10 hp of being stock anyhow.
The other reason is that every now and then you find yourself in a freezing climate and are glad you didn't change the thermostat or anything related. been there done that with iced up carbs, cars that wouldn't start at 10 degrees or ever reach temperature.
Old Dec 19, 2009 | 12:30 PM
bacord's Avatar
bacord
thanks for replys, "aminnich" and "aboatguy" is what i was thinking. Why spend the money for the couplings???? thanks for the pictures. I live in florida and the car just seems to run hot, about 210 and its not even summer..
Old Dec 19, 2009 | 12:41 PM
aminnich's Avatar
aminnich
The by-pass will have no affect on the engine operating temperature. Factory spec is a 185*F t/stat, but the engine fan operating parameters are why they run hotter than most cars.
Specification is fans on low at 227*F and 236*F for hi fan speed. GM did it this way to reduce emissions and further warns that up to 240*F is ok, but at 260*F shut the engine off and let it cool. Hope this helps.
Old Dec 19, 2009 | 12:53 PM
bacord's Avatar
bacord
I was looking to get a adjustable temp fan controll and 180 thermostat. What would be a good on and off temps?? and is the one style with the probe you put on a cooling fin any good?? What brand is recmonded??
Old Dec 19, 2009 | 01:35 PM
tblt44's Avatar
tblt44
I thoght factory t stat temp was 195 ?
Old Dec 19, 2009 | 02:08 PM
aminnich's Avatar
aminnich
I that factory t stat temp was 195 ?
Could be. I get the numbers confused at times. I went with a custom tune on mine and it stays about 190 to 210*F no matter what, even at the track.
There are other fan control options and the best other than a custom tune is probably the one sold by Corvette Central, MidAmerica, or one of the Corvette specific supply houses. Check their websites.
Old Dec 19, 2009 | 04:08 PM
STL94LT1's Avatar
STL94LT1
180* stats on all LT1's.
To new ideal???
