Factory PCM and Opti limits?
Old Dec 19, 2009 | 09:41 AM
aboatguy's Avatar
aboatguy
Default Factory PCM and Opti limits?
I've read that the factory PCM can't handle higher rpms and that the OPTISPARK is a grenade at 6000rpm.
I don't buy it..check this out 6972 on my daily driven 355 with an OEM opti from a EBAY supplier...and I'm getting ready for a tune up...plugs have about 10K on them (autolight 104s) and probably 30K on the unmolested opti.....
Old Dec 19, 2009 | 11:03 AM
mike100's Avatar
mike100
I do not know what the upper limit is on the opti-system, but it has to be the same as an old HEI or any of the single coil GM systems preceding it. The biggest issue is that it is a single coil and the amount of time it has to reach saturation is a lot less than if you had 4 or 8 coils like on the newest cars. Then there are the cap and rotor losses, the longer plug wire lengths and so on.
You can certainly go higher than 6k rpm, but it gets challenging if you are forced induction or real high cylinder pressure- MSD boxes do tend to boost coil output though.
The other issue, which might be opti-specific is that the optical sensor may get false signals if there are any reflective surfaces in the unit or if the device itself has an signal timing limitation. The old aftermarket Mallory smallblock chevy distributors used optical triggers and if you didn't take steel wool to the inside of the cap or just plain ran it to too high of a load at 6500 rpm plus, it started missing big time.
Old Dec 19, 2009 | 04:19 PM
STL94LT1's Avatar
STL94LT1
Mine has seen 67-6800 rpms a few times, and 6500 frequently. This is on a 30k mile stock shortblock.
Old Dec 19, 2009 | 04:22 PM
93VettePilot's Avatar
93VettePilot
I know alot of guys that spin their opti's to 6800 put a couple of rivets in the rotor to keep it from having a come apart.
Old Dec 19, 2009 | 05:38 PM
aboatguy's Avatar
aboatguy
Thats how I was with my stock shortblock too....however, back in the summer of 2006 one of the factory hyper piston decided it did not like the transition to sea level.
6972 without opening the opti......and its my daily driver that's hit 7005 more than once (7005 is the fuel cutoff speed so I know for sure when its hit 7005)
Old Dec 21, 2009 | 11:18 PM
Mojave's Avatar
Mojave
The factory PCM is limited to 7400 RPMs.
Old Dec 21, 2009 | 11:28 PM
larry00's Avatar
larry00
Yep designed for 7700 max RPM 's but 7400 would be reasonable .
An engine that lives at those RPM's is likely full race and would be going Mag at that point !
Mines built for 7,000 plus but I limit it to 6200 ! I'm running a stock OPTI even though I have an LSX timing cover with crank trigger !
I haven't found it necessary to put on coil paks yet !
Old Jun 2, 2010 | 08:58 PM
aboatguy's Avatar
aboatguy
I was looking at some of my data logs and decided I had to revive this one just to state for the record 7005 is not my cutoff in 3rd... OEM OPTIS RULES>>>>>>>>
Old Jun 3, 2010 | 10:00 PM
MK 82's Avatar
MK 82
I blast my LT4 to 6500-6600 routinely.
Eddie
To Factory PCM and Opti limits?
