do these look right?..84 Vette
Old Dec 21, 2009 | 02:26 PM
mazdaverx7's Avatar
mazdaverx7
Default do these look right?..84 Vette
since i'm fairly new to the Corvette world, i want to make sure my 84 is up to par and that everything is in place with the proper hardware.
first off, the right headlight is not opening when the hood is closed. i disn't see anything in the way. perhaps i'm missing something. anyone see something i'm not:
next is this little black box..looks like it may be a relay..what is it and what do the proper fasnters or scres look like to mount it:
is this resistor supposed to be in place..looks kinda odd with exposed wiring:
something doesn't look right here (other than the disconnected underhood light) am i wrong?:
Old Dec 21, 2009 | 03:12 PM
pmihaltian's Avatar
pmihaltian
Slingshot
This looks like the fan relay located on the driver's side inner wheel well. These are held in place by simple plastic push pin rivits. You can get a couple at your local GM dealer or the local Napa store.
Old Dec 21, 2009 | 03:19 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Check out the Sticky by Schrade at the top of the page on how to repair your headlights....
Old Dec 21, 2009 | 03:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I'm not famiiar with 84, but that could be the capacitor in the horn circuit.
From my 86 FSM http://members.shaw.ca/agent86/Horn%20Electrical.pdf
Headlight doors http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old Dec 21, 2009 | 05:26 PM
mazdaverx7's Avatar
mazdaverx7
both headlights open and close with no issues with the hood raised slightly. that right light is hanging up on something.
thanks for the responses thus far!! i'll have to snag those push pins for the fan relay!
Old Dec 21, 2009 | 05:34 PM
jhammons01's Avatar
jhammons01
Has to be a wire going into the headlight bucket when the hood closes....
I mean it like this....as the clamshell closes a wire folds into the headlight bucket assembly and holds it....I think....
Old Dec 21, 2009 | 05:37 PM
mazdaverx7's Avatar
mazdaverx7
i'll post a video of the issue..brb
Old Dec 21, 2009 | 05:52 PM
mazdaverx7's Avatar
mazdaverx7
first video is of the headlight issue with the hood closed.
mazdaverx7's Avatar
mazdaverx7
second video is of the hood open and the lights functioning normally:
Old Dec 21, 2009 | 05:53 PM
mazdaverx7's Avatar
mazdaverx7
as a note, i'm not sure how much force is needed to hang one of the lights up..maybe a wire..i was thinking it may be hanging up on the overflow bottle..
Old Dec 21, 2009 | 06:12 PM
motorjunkie's Avatar
motorjunkie
It looks like the headlight cover has a busted place right where mine did. The hood prop was bent the wrong way, and the headlight was coming in contact with it. Are you bending the hood prop forward or toward the rear of the car? It is supposed to go toward the rear.
IMHO the electrical has nothing to do with your problem. Something solid is in the way.
Old Dec 21, 2009 | 07:00 PM
mazdaverx7's Avatar
mazdaverx7
the prop rod bends towards the rear. no wear on the light bucket that i can see. i can post a pic if need be though.
Old Dec 21, 2009 | 08:20 PM
joeld's Avatar
joeld
Looking at the first picture it looks about the same as my 89, which did exactly the same thing you are describing. I moved the over-flow hose clamp rearward and this solved my problem. It's looks like there is the same threaded hole on your rail about 2 inches back from where it's secured now. Just move the clamp back and try to keep the clamp "twisted slightly" towards the engine as you secure to bolt.
Joel
Old Dec 21, 2009 | 11:10 PM
mazdaverx7's Avatar
mazdaverx7
^^thanks! i'll give that a try tomorrow after work!
Old Dec 22, 2009 | 12:21 PM
mikeremax's Avatar
mikeremax
or lower the over flow tank. Mine hit the tank it self.
Old Dec 23, 2009 | 09:57 AM
mazdaverx7's Avatar
mazdaverx7
i thought it might be the tank but why would it hit the tank, lol. the dumb thing is designed to be there, lol.
Old Dec 23, 2009 | 04:23 PM
pletzvet's Avatar
pletzvet
I suspect that the headlight motor is on its way out and doesn't have the capacity to open the headlight fully with the hood closed but with the hood open, gravity is helping it out. Have you checked for restrictions by having some one pull the lights on while you stand by the right headlight and assist it a little when it stops?
To do these look right?..84 Vette
Old Dec 23, 2009 | 04:48 PM
mazdaverx7's Avatar
mazdaverx7
have not tried that..i may give that a shot tonight.
Old Dec 23, 2009 | 05:03 PM
jhammons01's Avatar
jhammons01
Just have a friend pull the light switch while you stand near. As the bucket turns, help it along and see if just a little push from your hand will allow it to finish. If so, then it is the motor itself getting weak.
If something is binding it, you'll know right then.
Old Dec 23, 2009 | 05:08 PM
mazdaverx7's Avatar
mazdaverx7
well, i'm in the garage now changine the plugs so i'll give it a shot and report back
