Backfiring
Old Dec 21, 2009 | 02:59 PM
Roonster's Avatar
Roonster
6th Gear
Default Backfiring
Trying to figure out a problem I am having with my 82 TA w/CFI. It backfires out of intake manifold when I mash the throttle. I checked all vacuum lines and did find the hose bad going to the MAP sensor. Replaced it along with the sensor. Checked timing. Before checking, I jumper the diag. port A-B to disable electronic timing advance. (some models you have to disconnect the EST) I keep timing at 6 degrees BTDC to spec and it will backfire. Set timing to 10-12 degrees BTDC and the backfire goes away. Any ideas?
Old Dec 21, 2009 | 03:07 PM
mazdaverx7's Avatar
mazdaverx7
have you tested the fuel pressure? does it only have the problem when the engine is cold?
Old Dec 21, 2009 | 03:35 PM
Roonster's Avatar
Roonster
6th Gear
Default Fuel pressure
Haven't checked fuel pressure. I have to check by teeing into the line?
To Backfiring
