?'s...MN6 durability with solid flywheel
Old Dec 22, 2009 | 08:03 AM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Default ?'s...MN6 durability with solid flywheel
If you have a Vette with and MN 6 and you put in a solid flywheel with a sprung clutch and get the tradition can of rocks sound. Is there a durability issue for the transmission?
Old Dec 22, 2009 | 09:45 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
I always wondered that myself. If I was going to do that change to my zf6spd I would drop an e-mail with Bill at zfdoc.com just to see what his thinking on the question would be.
fwiw, I remember reading somewhere that Ford used a D/M fly wheel in a mustang application(?) and the reason given was to dampen out the vibrations from the motor before they got transmitted to the transmission. I don't know for sure if that is indeed a fact. I never ran it down because I'm not in need of a new flywheel, yet.
I know it's a popular swap in the ZR-1 community. Most of our tuners say it allows for a faster spool up of the revs so we get into our power band quicker. I have never seen a zf 6spd failure linked to the use of a solid fly wheel in any of our technical threads at our forum.
Tom
Old Dec 22, 2009 | 02:58 PM
neat's Avatar
neat
I've had one for 20K with no issues.
Old Dec 22, 2009 | 03:39 PM
NMsharkracer
any opinions or comments on steel vs aluminum? Any recommendations on flywheel/clutch combinations?
Old Dec 22, 2009 | 04:58 PM
VetteMed's Avatar
VetteMed
I remeber reading that the reason the Dual-mass flywheel was specified for the C4, was because of the feeling that corvette buyers would not want the level of noise/harshness that came from the beefy construction of the ZF6. I don't think it was a durability issue.
Old Dec 22, 2009 | 08:34 PM
Red Rocket's Avatar
Red Rocket
Have used the LT1 Camaro Flywheel and numerous clutches the past ten years of drag racing. The steel Camaro flywheel weighs about 20 lbs which is about 18-20lbs lighter than the DMF. It seems like the extra weight versus aluminum does help on the noise.
The Spec 3+ is by far the best clutch. Nothing but problems with the Mcleod Kevlar clutches pucks, etc. With my current set up the car idles at 1050RPM's. No issue with noise. Finally broke into the 11's with the 350 going with the SMF.
Old Dec 26, 2009 | 12:30 AM
Snakecharmer383's Avatar
Snakecharmer383
This summer I went to a SPEC Stage 2+ with alum. flywheel from stock. Def. revs quicker and I'm now breaking the tires loose in 2nd which I wasn't before. (did get other mods done at same time) With about 500 miles on the car the clutch feels stock. Can't wait till spring!!
I called SPEC directly and dealt with them without any problems.
Old Dec 26, 2009 | 02:51 AM
tpi 421 vette's Avatar
tpi 421 vette
Durability isn't a issue with a solid flywheel. A higher idle and sprung disc helps quiet the gear rattle. And the ZF will handle alot of power. My old motor made 720rwhp and 790rwtq. I haven't dynoed the car the new 450, but it probably makes 50-75 more hp and more tq, and works perfect. The ZF if shifted properly will handle alot of power.
Old Dec 26, 2009 | 03:50 AM
tpi 421 vette
I probably ought to add that the ZF6 is the only part of my drivetrain that is original and has held the the abuse of hardcore drag racing. Everything before it and behind it has been heavily modifided.
Old Dec 26, 2009 | 08:19 AM
NMsharkracer
From what I've gathered, outside of the noise issue, there's no issue of accelerated wear or damage from using solid flywheel combinations.
Old Dec 27, 2009 | 05:39 PM
856SPEED's Avatar
856SPEED
SMF are fine.....aluminum FW's just allows you to hear gear rattle due to how the ZF gears are cut.....no problem in durability with the ZF's.....failure rate is quite low(never heard of one actually).....very strong tranny's
Old Jan 16, 2010 | 09:10 PM
lcvette's Avatar
lcvette
I can vouch mine held 900+whp without a grunt with 335 hoosier drag radials out back. I also run a singlemass flywheel with the McLeod Street Twin.
thinking this time around I may try the new Spec supertwin push style clutch system. anyone try this?
Chris
To ?'s...MN6 durability with solid flywheel
