C5 Wheels
Old Dec 28, 2009 | 03:26 AM
jaxvet's Avatar
jaxvet
Default C5 Wheels
Friend has C4 coupe & C5 vert w / stock factory 5-spoke wheels & tires. Wants to put C5 combo on the C4 & get new whls / tires for the C5
Will that work clearance wise, does he need spacers or anything, stock 17X8.5 & 18X9.5 & stock tire size on the C5
Old Dec 28, 2009 | 07:19 AM
rodj's Avatar
rodj
Year model of C4 you are asking about would help.
C5 wheels fit 88- 96 without spacers.
84 -87 require 3/4" spacer to sit in right position otherwise they are too far in under the guards
Old Dec 28, 2009 | 05:33 PM
jaxvet's Avatar
jaxvet
Sorry - it's a 96 - thanks for quick info, that is what he needed to know.
Old Dec 28, 2009 | 11:36 PM
96 lt-4's Avatar
96 lt-4
Will work fine.I have had them on my car and am switching back to them.I do switch the fronts to stock size(255/45/17).I don't like the lower ride height on the C5 fronts(245/45/17).My car has been lowered.It may not be an issue on a stock height car.
Old Dec 28, 2009 | 11:39 PM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
I have a 96, with the tire and wheel sizes you said, and they fit fine, no problems whatsoever and spacers were not needed!!!
Laura
Old Dec 29, 2009 | 03:32 PM
auskey's Avatar
auskey
8th Gear
I have a 1988 c4 with the same wheel set up.. running 245/45r17 Fronts and 255/40r18 Rears.. correct tire size set up for the rear is 275/40r18......
Tires Bridgestone Adrenalins
To C5 Wheels
