C4 Front Brake caliper Mount Brackets
Old Dec 28, 2009 | 03:12 PM
LT1 Rocker's Avatar
LT1 Rocker
Default C4 Front Brake caliper Mount Brackets
I noticed considerable wear on the front brake brackets on my high milage 1989 and just filed the area where the pad metal backings rub against the brackets. There is a groove wearing in the aluminum brackets.
Because the front brakes some timetimes have a slight pull either to the right or the left, I suspect that it is being caused by the irregular worn pad backings.
NewGMparts.com lists them for $55 each but come right down to ordering they cost over $70 each plus shipping from the classic parts warehouse.
Does anyone know a more resonably priced source to buy these brackets?
Right- 10181207
Left- 10181208
Happy Holidays
& Thanks
Old Dec 28, 2009 | 03:26 PM
c4cruiser's Avatar
c4cruiser
You will probably find that it will be a GM item only. The p/n looks like they are for the J55 brakes so that might explain the higher price.
GMPartsHouses.com wants $58 each (Gene Culley is a Forum Vendor). You might also try Ken Fichtner Chevrolet. Thats the "Ken's Newsletter" section of the Professional News, Article's, and Tips section of the forum. He can help too.
But according to the Superior Chevrolet website, the GM big brake abutment brackets are no longer available from GM.
Old Dec 28, 2009 | 04:06 PM
Aardwolf's Avatar
Aardwolf
Have a local welder add some metal to the worn area? $10?
Old Dec 29, 2009 | 03:00 PM
LT1 Rocker's Avatar
LT1 Rocker
Default Idea
Off to the welder it is! I believe that they would do it inexpensively and they will be as strong or better than the originals.
Thanks Guys!
Old Dec 29, 2009 | 03:40 PM
Sidney004's Avatar
Sidney004
Check your wheel bearings. Something is not right.
To C4 Front Brake caliper Mount Brackets
