ProCharger
Old Dec 28, 2009 | 09:43 AM
cmtatlanta's Avatar
cmtatlanta
Default ProCharger
I have a squeak on my 95 vette that is proportionate to engine revolutions. At idle it squeaks about every ¾ of a second. It’s barely audible inside the car. If the Procharger head unit had a bearing going out it would be constant and probably have a roar vs. a squeak, right? It has 20K trouble free unabused miles on it.
Old Dec 28, 2009 | 09:57 PM
dizwiz24's Avatar
dizwiz24
which procharger model do you have? My p600b is squeaky and thats normal. Its just a 'loud' blower.
You mention 20k trouble free miles, Im going to guess that something has changed in the normal noise you are used to.
Maybe its the alternator?
Are you running a 6 rib setup (with the serpentine accessories driven off the same belt?) or a separate, dedicated (it only runs the blower) 8 rib setup?
Old Dec 29, 2009 | 10:48 AM
cmtatlanta's Avatar
cmtatlanta
It's a P-1SC and the noise is new. The alternator has 9K on it and I run the 6 rib serp. belt that runs everything.
Old Dec 29, 2009 | 09:33 PM
Brand-X's Avatar
Brand-X
Remove serp belt and turn every pulley, including idlers an accessories, and see if any feel rough, loose, or stiff. Also, is your crank hub keyed?
Old Dec 30, 2009 | 08:46 AM
cmtatlanta's Avatar
cmtatlanta
Will do. I'm pretty sure the crank hub is keyed
Old Jan 5, 2010 | 08:59 PM
Brand-X's Avatar
Brand-X
If you're not sure it's keyed then it probably isn't...good luck!
To ProCharger
