D44 R&P Swap
Old Dec 28, 2009 | 05:00 PM
MK 82's Avatar
MK 82
Default D44 R&P Swap
A recent thread has me thinking about doing a 4.11 swap on mine. Does anyone know of a step by step on this. What special tools are needed besides dial indicators for measuring backlash?
I am having a tough time finding someone local to do it who doesn't want an arm and a leg. Shipping the pumpkin is a big hassle.
Old Dec 28, 2009 | 05:08 PM
Pete K's Avatar
Pete K
To really do it right, you need:
Case spreader
Dial indicator and stand
Hydraulic press
Bearing seperator
Bushing /Bearing drivers
Pinion Depth Checker
Dial torque wrench
Hand tools
There are 3 basic process to setting up rear gears.
Proper pinion Depth
Proper Backlash
Correct preload on pinion and carrier bearings.
If the above is right, it will live.
Old Dec 28, 2009 | 06:05 PM
toptechx6's Avatar
toptechx6
Someone posted these plans for a spreader you can make yourself. Sorry I don't recall who did the work.
I have a dial indicator and hydraulic press you are welcome to use if you can come up with the pinion depth gauge, good luck with the project.
Old Dec 28, 2009 | 06:25 PM
MK 82's Avatar
MK 82
I assume the case spreader is to get the carrier in and out?
If you save the pinion shims from the old pinion, do you really need the depth checker. With the dana 44, you also need a set of test bearings that have been reamed out a few thousands so you don't have to press them on and off while changing shims.
Thanks for the offer, Jim. Have you done one? I may give it a shot. I have Paul Zank's DVD. He addresses the D44 but not the Corvette one.
What gear set should I buy?
Old Dec 28, 2009 | 07:16 PM
toptechx6's Avatar
toptechx6
Yes the spreader is for removing the carrier from the case, also helps to have the correct bearing pulling tools, and having a trial bearing set is a good idea, even with the correct tools the bearings can be damaged during removal which is often necessary during adjustment.
I have done many rear ends, but not a Vette or Viper. I have seen techs reuse the original pinion depth shims adjusted for the + or - markings on the replacement gear set but I would not rely on it.
Even when using the pinion depth gauge, reading the pattern is considered the best indicator of correct set up.
The genuine Dana gear set seems to get the best reviews from what I understand, the 4.10 ratio may be available from a Mopar dealer. If you have trouble locating them, let me know and I will make some calls.
Old Dec 28, 2009 | 07:38 PM
MK 82's Avatar
MK 82
I would start out with the same thickness pinion shim and adjust to get the best pattern.
Mine is a three series carrier so I guess I will need the "thick" gears. Does Dana make those?
Old Dec 28, 2009 | 07:40 PM
STL94LT1's Avatar
STL94LT1
I would definately go with the Dana/Viper 4.10's. Mine are quieter than the stock 3.45's.
Most aftermarket gearsets come with a crush sleeve, not shims.
IMHO C4 gear changes should be left to professionals, not most of us part-time wrenchers. But, if you decide to do it yourself, good luck and don't forget the pics.
Old Dec 28, 2009 | 07:47 PM
STL94LT1's Avatar
STL94LT1
As you can see the Dana ring gear is larger than the stock unit. Some D44 carriers will need to be clearanced to run the larger Dana gear.
Old Dec 28, 2009 | 08:43 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
The part number for the Dana 410 is P5007043.
If you decide to change the clutch pack the Spicer p/n is 707018X.
For the rebuild kit, stay away from Motive. They had the wrong shims in the kit, they had the shims for the jeep Dana 44, yet box was marked for a Corvette IRS Dana 44.
Old Dec 28, 2009 | 10:50 PM
MK 82's Avatar
MK 82
The crush sleeve is for preload. Dana does not use them.
The professional thing took longer than I expected. It's not rocket science. A man has to know his limitations.
Old Dec 28, 2009 | 11:03 PM
Pete K's Avatar
Pete K
There is a simple way around the case spreader.
Warm the housing with a propane torch, and keep the diff in the freezer.
After a minute or 2 of case warming, the diff drops right in.
Old Dec 28, 2009 | 11:10 PM
James93LT1's Avatar
James93LT1
This site helped out a bunch when I did mine
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
Having the proper tools makes all the difference in setting gears.
Old Dec 29, 2009 | 10:28 AM
STL94LT1's Avatar
STL94LT1
My Dana OEM 4.10 gearset came with a crush sleeve.
Old Mar 25, 2010 | 08:33 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
so, did you do it yet?
Old Mar 26, 2010 | 09:25 AM
Jagdpanzer's Avatar
Jagdpanzer
I’ve done a few Corvette Dana 44 gear changes and trust me it will be a "valley of tears experience" if you don’t have all of the right tools or the knowhow.
Old Mar 27, 2010 | 02:20 AM
BrianCunningham
Old Mar 27, 2010 | 03:51 AM
jmartynuska's Avatar
jmartynuska
My '89 FSM calls for adding/subtracting shims to set pinion preload. I'd read that to mean no crush sleeve.
Old Mar 27, 2010 | 06:33 PM
vette punk's Avatar
vette punk
Default R&P Swap
Who would be some reputable shops to do a gear swap? Randy's,Tom's etc.?
Jim B.
Old Mar 28, 2010 | 01:57 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Another possiblity is that the kit was for an 80-82 Vette. As they are listed as a IRS Dana 44. The same only diffrent. I know as I have one. Take care...
To D44 R&P Swap
