??? 95 Corvette brake rotors, SD or HD ???
Old Dec 29, 2009 | 03:21 PM
Showcase1186's Avatar
Showcase1186
Default ??? 95 Corvette brake rotors, SD or HD ???
I am in the process of ordering replacement rotors for my 95 vette. I don't know if I have Heavy duty brakes or standard duty brakes. What is the difference? Can I use the heavy duty rotors if I currenty have standard duty rotors? Thanx for your help!
Old Dec 29, 2009 | 03:29 PM
aboatguy's Avatar
aboatguy
If you are still stock you have the J55 (bigger 13" front rotors)
Old Dec 29, 2009 | 04:05 PM
StealthLT4's Avatar
StealthLT4
1) You have Heavy Duty brakes (J55 option, 13" front rotors)
2) The difference is only the size of the front rotors. The calipers are (I believe) the same, as are the pads, just a difference in the mounting brackets on the front. Don't take my word on that though...
3) No, you would have to buy new caliper mounting brackets to use standard rotors on your J55 car.
FYI, all '95 and '96 cars came with J55 brakes standard. Also, www.corvetterecycling.com is a great place to get rotors. They have new-in-box AC Delco rotors for $20 each, a price which you would be hard pressed to beat even with cheap Chinese stuff.
Old Dec 29, 2009 | 04:35 PM
aboatguy's Avatar
aboatguy
I was going to post about the 20 dollar OEM rotors at Corvette Recycling and the brembo pad closeout at Tire Rack I even have the link opened in another tab to attach it but I got sidetracked.......Damn attention deficit disorder
Old Dec 29, 2009 | 05:24 PM
toptechx6's Avatar
toptechx6
The calipers are different as well, slightly wider than those with JL9 because the 13" rotor is thicker.
Old Dec 30, 2009 | 01:44 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I bought a set of 4 rotors from them 6,000 miles ago. Cannot beat their price for NOS oem rotors.
Old Dec 30, 2009 | 08:01 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
So jl9 is standard and jl55 is hd coorect?
Old Dec 30, 2009 | 10:03 AM
aminnich's Avatar
aminnich
Correct (sorta). In 95 the J55 became standard, so standard for 95-96 was an option for earlier years.
To ??? 95 Corvette brake rotors, SD or HD ???
