door ding problem
Old Dec 31, 2009 | 01:00 PM
m.kempel's Avatar
m.kempel
4th Gear
Default door ding problem
Hello,
my door chimes only seem to work when the car is cold. When the car warms or the weather, they stop working.
This is both the key ignition chimes and the door ajar lights on signal.
Any ideas?
Thanks,
Mike
Old Dec 31, 2009 | 01:37 PM
xole's Avatar
xole
There is a door ding and headlight warning?
Mine has never made a sound since I have owned it. In looking in the FSM there is a chime module burried in the dash.
Old Dec 31, 2009 | 03:04 PM
m.kempel's Avatar
m.kempel
4th Gear
there are two different warnings;
one when the key is in the ignition and the door is open
and another when the lights are on and the door is open regardless of the key.
They are the same sound, different frequency of ding.
Mine both work, but only under the right conditions.
Regards,
Mike
Old Dec 31, 2009 | 08:42 PM
Gear Jammer's Avatar
Gear Jammer
Active Streak: 90 Days
Hello,
On my 91, the chime module wouldnt work either. However, I was able to fix the chimer. All I did was to remove and disassemble the chimer, and re-solder the joints where the plug-connectors are soldered on the PCB. Been working for almost a year now.
Obviously, the hard part is removing the dash top to get to the chimer box (really not that hard, but tedious).
john
Old Jan 1, 2010 | 03:31 AM
pologreen1's Avatar
pologreen1
I had an 89 that chimed too much, it had to do with something on the switch.
Old Jan 1, 2010 | 11:25 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Mine only chimes when it wants to mess with me.
It usually doesn't chime but one day it did as I was getting out and it scared the crap out of me. I thought is was going to blow up or something.
To door ding problem
