fuel Injector Cleaning question
Old Dec 31, 2009 | 06:06 PM
ksch994462's Avatar
ksch994462
Default fuel Injector Cleaning question
My 1990 L98 is idling rough. I'm thinking about using a 3M Fuel Injector Cleaning Kit on it. Has anyone had any experience with this kit? Any positive results, or is it a waste of time and money? I've already done plugs, wires, cap & rotor. Thanks...
Old Dec 31, 2009 | 06:13 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
if you have gm mulecs that came stock they are not to be cleaned. You will ruin them. Here is a bulletin from AC Delco. Make sure you Ohm check them cold and hot to make sure they are in spec.. they should be 16ohms
here is the Bulletin
http://www.acdelcotechconnect.com/pd...sb_05D-105.pdf
Old Dec 31, 2009 | 06:59 PM
ksch994462's Avatar
ksch994462
Thanks alot for this info. You probably saved me from making a BIG mistake. I ohm'd the injectors recently and got 16.9 - 17.2 readings on them. The engine was cold at the time. I can also feel them "pulsing" as the engine is running, so I assume they're injecting. I'm trying to figure out what I can do to make the engine idle more smoothly. I'm planning on checking all the vacuum hoses next to make sure I don't have any cracks, etc. I'm NOT going to start replacing good components. Thanks again.
Old Dec 31, 2009 | 07:25 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
hi jon,
Question, another member is having an issue with his plugs fouling I believe?
The PO put 24Lb injectors on what I believe to be a stock l98. What issues can the 24Lb injectors create, if any?
Old Dec 31, 2009 | 07:38 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
thanks
Old Dec 31, 2009 | 07:44 PM
SunCr's Avatar
SunCr
I've used 3M cleaner through the rail on a couple of GM cars (including the Vette) - didn't do anything good - or bad for that matter. A cheapo set of Accels (injectors) did solve a hard cold start which was present from the Factory, but that's another story.
If you have a rough running '90, or a less than perfect idle; check #7 for a leaking head gasket. A known issue and a cylinder leak down test is the better way to check it out (though you can check compression). Otherwise, if you have the old plug, how did that electrode look compared to the others? Was there any rust on the plug threads? What's the coolant look like? If you have a scanner, check Block Learn - coolant will make it lean.
Old Dec 31, 2009 | 09:50 PM
samsonb's Avatar
samsonb
Is it okay to put in those gas treatments that remove water? I think I put in some STP the other day, though I usually use that Heat stuff in the winter.
Old Dec 31, 2009 | 10:54 PM
grantar2's Avatar
grantar2
Team, from my own experiance with both my cars and my outboards, it sounds to simple but before you spend serious cash, fill up with Chevron premium with Techron. Run two tanks. One the first tank or with whatever gas you have in the car now run a bottle of techron. You can buy it at parts stores or Wal-Mart. I know it sounds too simple and yes Shell, or Union 76 or any of the other quality fuels have cleaners. But I really it's isn't expensive use the Techron. If all you use is Chevron and your having injector problems I am going to bet there is another problem and not a dirty fuel system.
Old Dec 31, 2009 | 10:58 PM
ex-x-fire's Avatar
ex-x-fire
I have done canister fuel inj. cleanings lots of times, it does work. But it won't bring back dead injectors. I've used BG 44, OTC cleaner, & Seafoam w/ the canister, the eng. is running on 100% cleaner, on V8s I like to do a double shot, use 2 cans b/c 1 it won't run to long. If you think you might have a plugged injector, try feeding alittle propane into a vacuum hose, if it smooths out you have a fuel problem.
Old Jan 1, 2010 | 12:02 AM
samsonb's Avatar
samsonb
Are those Lucas products any good? I have read some say to use their fuel system product and no other brand. I know alot like Lucas for the power steering.
Old Jan 1, 2010 | 09:00 AM
Flame Red's Avatar
Flame Red
If you are after a smoother running engine, and increased gas milage, just replace the injectors with a set of flow matched Bosch Design-3 from Jon at FIC. My idle smoothed out, the engine sounded totally different (don't know why) and fuel milage when from 17 city to 24 and Hiway from 20 to 29!
I was shocked on how fuel injector technology has improved in 20 years.
Old Jan 1, 2010 | 10:02 AM
Muffin's Avatar
Muffin
What he said. Band Aids are good when you stab yourself with a screwdriver but nowhere else.
Old Jan 1, 2010 | 12:38 PM
FICINJECTORS
Supporting Vendor
There is no cure in a can. Period. These injectors get filled with small particles of carbon, this restricts the flow of injectors. Even if the coil is good, they just get mechanically sluggish. If you clean the injector (multec 1 only) you ruin the coil. It costs about 15 per injector to service. it cost 22 to get a new style injector that will not have any intolerance to the new fuels and best of all your car will run better. Kind of a no brainer
Old Jan 1, 2010 | 03:59 PM
grantar2's Avatar
grantar2
Are you running an L98 or LT1?
Old Jan 1, 2010 | 07:47 PM
FICINJECTORS
Supporting Vendor
he has a 90 l98
Old Jan 1, 2010 | 08:36 PM
samsonb's Avatar
samsonb
I wasn't really referring to cleaning the injectors. I see these things are supposed to clean other things in the fuel system other than fuel injectors. I just wondered if there were any benefit to have the rest of the system treated?
And is it any good or bad to put in the fuel system treatment that removes water? I believe last time I used the STP stuff, but I usually use the Heat.
The STP stuff doesn't have alcohol. Where as the Heat stuff does.
Old Jan 1, 2010 | 09:33 PM
FICINJECTORS
Supporting Vendor
i guess if there is no alcohol in the additive it would be ok.
Old Jan 1, 2010 | 10:21 PM
samsonb's Avatar
samsonb
So, is the alcohol water remover stuff bad to use then like the Heat? I've used that for years in my Firebird. I've also used the stuff in the yellow bottle that is by the Heat. Though, it may not even be needed, as I've never had any problems when I didn't use it. I just figured it wouldn't hurt to throw it in there every so often to help remove any possible moisture.
To fuel Injector Cleaning question
