Polyurethane Bushing Question?
Old Mar 4, 2002 | 02:06 PM
CG77VETTE's Avatar
CG77VETTE
Default Polyurethane Bushing Question?
I just purchased a complete suspension polyurethane bushing kit for my '86. I just have a few questions regarding the installation.
1.) How difficult a job am I looking at?
2.) What special tools will I need?
3.) Can this job be done using ramps and jack stands, or is a lift required?
Thanks for any help and advice.
Old Mar 4, 2002 | 02:39 PM
Ian94's Avatar
Ian94
Default Re: Polyurethane Bushing Question? (CG77VETTE)
It shouldn't be that difficult. I replaced the rear bushings on my 87. Just take your time, do one part at a time. I put mine up on jack stands.
I was going to do the fronts, but sold the car before I could. It really tightens up the suspension, you will really notice a difference in
ride quality. Just make sure you get enough marine grease on/in them.
-Ian94
Old Mar 4, 2002 | 03:02 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Polyurethane Bushing Question? (Ian87)
I second that. Just plan on taking your time. Get a suspension part out and work on that one thing until you are done and then do another part. To get the old rubber bushing out of the metal part I like to burn it out with propane. Just watch out for the metal sleeve in the middle. As the rubber is burning it will sometimes shoot the metal sleeve out with great force. I shot one across the garage. Can you imagine if it had landed in my oil drain pan or something? Good thing I keep a big extinguisher nearby at all time. I have heard of drilling holes in the rubber and hacking the bushing out. I like fire best.
Old Mar 4, 2002 | 03:03 PM
silver & red CE's Avatar
silver & red CE
I'm doing mine on jackstands in my unheated garage, (the beer stored in there is too cold to drink). Using a lift and air tools is for wimps ;)
Eric
Old Mar 4, 2002 | 03:05 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Polyurethane Bushing Question? (silver & red CE)
I think I resent that one, hahahahahahaha. Have fun.
Old Mar 4, 2002 | 03:36 PM
JonM's Avatar
JonM
Default Re: Polyurethane Bushing Question? (Bob86ZZ4)
There goes that Bob again...UPstaging us all :smash: :crazy: :smash:
Old Mar 4, 2002 | 04:15 PM
Bluevette85's Avatar
Bluevette85
I am doing this project now. Here are some tips:
1. Cut off rubber lip that sticks over end of suspension piece.
2. Drill many holes around the metal sleeve.
3. Remove metal sleeve with vise-grips by turning them in a circle.
4. Press out the old bushing with C-clamp and sockets or borrow a ball joint
press from autozone.
5. Clean out any remaining rubber.
6. Apply alot of grease to everything.
7. Take your time and expect it to take longer than expected.
Old Mar 4, 2002 | 04:45 PM
drive it's Avatar
drive it
Default Re: Polyurethane Bushing Question? (Bluevette85)
Ditto to all the above-plus how many miles are on it? If you're about 130k+ I'd really consider changing the ball joints etc. while you're that far into it. Oh yea-it'd probably be easier if you took it over to Bob's lift.....YES, I'm jealous of that lift! :D
Old Mar 4, 2002 | 06:13 PM
Bluevette85
Default Re: Polyurethane Bushing Question? (drive it)
I also agree with doing the ball joints and wheel bearings if the miles are high. I recommend the package availible from www.p-s-t.com because everything (except wheel bearings) is included and I couldn't find a cheaper price.
Old Mar 4, 2002 | 06:57 PM
85WHITEZ51's Avatar
85WHITEZ51
Don't you need a press to install the front A arm bushings and lower ball joints? That is what I was told so I had a shop do it for me. If you car has high milage then it will be a HUGE improvement. I love my new suspenision with poly bushing, new shocks, and new ball joints. I also got the adjustable strut rods in the back. Don't know if they do anything but I have them anyways. At least they make me think it handels even better.
Old Mar 4, 2002 | 07:54 PM
Bluevette85
Default Re: Polyurethane Bushing Question? (85WHITEZ51)
You do need a press but you can rent one for free at some parts stores.
Old Mar 4, 2002 | 08:42 PM
mash557's Avatar
mash557
I was also told by the guy at Suspension.com to run a fine thread tap through the inside bore of the bushings to create a "reservoir" for grease. sounds good in principle, anyone tried it??
Old Mar 4, 2002 | 08:47 PM
CaneinBatonRouge's Avatar
CaneinBatonRouge
Bluevette85, how do you like the P-S-T kit? I just got mine today and plan on installing everything this weekend(of course I do have access to lifts and presses :D ) I liked that everything metal had USA on it.
Old Mar 4, 2002 | 08:58 PM
VetteNoob's Avatar
VetteNoob
Default Re: Polyurethane Bushing Question? (CaneinBatonRouge)
CaneinBatonRouge,
Did your bushing kit come with the rear bushings too?
Old Mar 4, 2002 | 09:15 PM
Barrier's Avatar
Barrier
Default Re: Polyurethane Bushing Question? (VetteNoob)
I was thinking about the PST kit as well. I e-mailed them but got no response, my question was: Where are the ball joints and tie rod made? China, Mexico or the US/Canada? Are they name brands?
Does anybody know?
Was it necessary to grease with the graphite impregnated parts?
thanks
Barrier
Old Mar 4, 2002 | 09:30 PM
Bluevette85
You could probably do it over a weekend per side! While I had everything off, I degreased all the aluminum parts and polished them. Looks :cool: When I get to the back, the u joints are being replaced. I don't want to do this for another 135000 miles :D
Barrier: The ball joints and tie rods are Made in USA. I would call PST tech support as they are very helpful. It is necessary to grease. BUY EXTRA GREASE!!! Get 8oz more. The little tubes that come with the kit are not enough. You don't want squeaks in a few months.
[Modified by Bluevette85, 8:32 PM 3/4/2002]
Old Mar 4, 2002 | 09:51 PM
CaneinBatonRouge
VetteNoob, no the rear bushing kit is sold separately($90, if I remember right), If I like the front kit after it's installed I plan on getting the rear kit also.
To Polyurethane Bushing Question?
Old Mar 4, 2002 | 10:00 PM
85WHITEZ51's Avatar
85WHITEZ51
I don't think you will get the full potential of the poly front kit with old rubbers in the back. Could be wrong but in therory it would compromise the quality of the fronts feel.
Old Mar 4, 2002 | 10:27 PM
RocketSled's Avatar
RocketSled
Aww heck, I'll see bob and raise him a nother bay. :p:
(And urethane bushings are on the shortlist, but I gotta get the motor in first! http://millerville.cc )
Old Mar 4, 2002 | 10:29 PM
96LT1's Avatar
96LT1
I did the front end on 86 last winter. Bushing, ball joints, tie rods. Don't even think about pressing the lower ball joints in without a hydraulic press. It took me a half day to remove each side with a manual press. I had to take them to a shop to get them pressed back in. The bushing on the front weren't bad. Just be sure to use lots of grease when you install them. Some people have mentioned using marine grease. There isn't usually enough in the package.
As far as only doing the front goes, thats all I did last year. I was planning on doing the rear this winter but doing motor work instead. The car is a little 'loose' in the rear but not noticable until it is pushed hard.
