Differences between L98 and LTx heads?
Old Jan 6, 2010 | 05:06 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Differences between L98 and LTx heads?
Is there a difference that can be overcome within the differences? Just thought I would look into wether you can mount L98 Heads (better and cheaper AFR selctions for example) onto an LTx engine.
Pictures are always a good way to show the difference.
Old Jan 6, 2010 | 05:13 PM
STL94LT1's Avatar
STL94LT1
I remember Tom Wong telling me about an LTx engine he was working on that had SBC heads. Seems like the conversion price for the heads was $300 or $400.
Old Jan 6, 2010 | 06:25 PM
rodj's Avatar
rodj
Would be the reverse of this ? Scroll down
http://www.fullsizechevy.com/forums/...gen-1-sbc.html
Would have to make coolant holes in the heads to match LTX block and redrill intake bolt pattern
Old Jan 6, 2010 | 08:45 PM
steve40th's Avatar
steve40th
Doesnt look like a lot to do, as 3-4 hundred bux is about 4 hours of work.
Old Jan 6, 2010 | 11:30 PM
96GS#007's Avatar
96GS#007
...also have to address the fact that the LT1 intake is dry while the Gen 1 heads flow coolant thru the intake and there is a steam vent line at the rear of the LT1 heads but not the Gen 1 heads. The steam line is due to the reverse flow cooling.
Hell of an experiment to save $300 only to find out the cooling flow is fubar'ed and you overheat the engine. JMO
Old Jan 6, 2010 | 11:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
Cheaper to buy the LTx head
Old Jan 7, 2010 | 11:16 AM
steve40th's Avatar
steve40th
Makes sense to just go with LTx heads. I wish GM would have just stuck with GENI tech, for the most part.
Old Jan 7, 2010 | 11:43 PM
88BlackZ-51's Avatar
88BlackZ-51
Yeah. I wish they would of stuck with the Gen1 period. No opti crap!
Old Jan 7, 2010 | 11:46 PM
steve40th's Avatar
steve40th
I am thinking a 91 Six speed, aftermarket block, 427... HMMM
Old Jan 7, 2010 | 11:47 PM
88BlackZ-51
That sounds about right, or you could go with a 421.
Old Jan 7, 2010 | 11:55 PM
steve40th's Avatar
steve40th
The 427 Bill Mitchell engines sound good. A friend had one here in Hawaii in his C3. Super Sweet.
To Differences between L98 and LTx heads?
