Hey guys. I am having a hard time with the harmonic balancer. We cleaned it up and lubricated it a little, but it doesn't seem to want to draw up like it is supposed to. Is it normal for these to be so tough to get back on, or should it pretty much just slide into place? I was just using the bolt to draw it up rather than an installer. Will the installer really make any difference?
Using just the bolt to try to press on the damper is the wrong way to go about it. That often leads to stripped threads. You need an installer. AutoZone loans them.
Yeah, the install tool is the way to go. All the friction is greatly reduced by the bearing on the tool. I like to put assemebly lube on the crank snout to easy the procedure. The problem w/ using the bolt is that it's only 7/16 dia. so it's kinda small.
yeah, the install tool is the way to go. All the friction is greatly reduced by the bearing on the tool. I like to put assemebly lube on the crank snout to easy the procedure. The problem w/ using the bolt is that it's only 7/16 dia. So it's kinda small.
As always....thanks guys. That is what my brother said as well. He works for a restoration shop and has some pretty good skills when it comes to these things. Got a picture of my boy sitting in front of a 67 427 when I was there a week or so ago......and it had air conditioning so it was worth some money. What a beautiful ride that was. The guy had twinkie 87 callaways too. Anyways, thanks for the advice. The project is coming along. The heads are on and the cam is in, so we are making good progress. No one has a set of long tubes sitting around that they would want to give me do they.
I went with the Mcgiver method, long bolt and nut with 2 greased washers. Thread the bolt into crank and use the nut and washers to pull the hub on. It's not that I'm cheap, oh wait, it is because I'm cheap.
smear a bit of 'go-joe' hand cleaner or any similar hand treatment that contains 'lanolin' (check wif's 'hand lotion', don't tell) on both parts, press on before the stuff evaps
Use the proper tool on this job - even with the crank stub and the inside of the HB lubed, it is a pretty tight fit and takes some torque. If you look closely on the threads of the installer shown in the picture, you can see how they have lost their pitch. Not sure how many times that installer has been used, but you don't want to take the threads out of the end of the crank or snap the stud. Even more important is the HB butts up against the lower timing chain gear to keep in lined up with the upper gear so if you don't get the HB all the way on, you could end up doing a lot more damage.
That's exactly what I used and it worked perfectly.Or you can pay big bucks for a Kent Moore tool that will do the same thing.
Well said and great advice!
I've had my hub off several times in the past few months. At first I was using the bolt like you are because I thought I was only going to do it once, not the case unfortunately. On the third time I tried reinstalling it with the bolt the crank threads started to fail. I was lucky and got a tap and ran it in the crank snout to salvage the threads. I now have a Kent Moore tool I bought on ebay to do this with. Works great and pulls the hub up tight with little work. The secret is the thrust bearing. It takes the load off of the threads. It's also best to use some high pressure grease on the threads to help protect them. Youdo not want to ruin the crank snout threads!Rent a tool or buy one!
I keep saying that I am going to post pics, but the project keeps dragging out for one problem or another......or just time. It is stinking nasty cold right now. They are saying that we might hit 14 below in ol' kc tonight.
Thanks for all of the above advice. I will do a start to finish photo show for you when she is done, but here is a teaser just for you Gregg.
Alright guys. I will be hitting it again this Saturday. Wish me luck and really good progress. I have to get the balancer on there, set the valve lash, install the new intake, and then figure out what to do with the 2000 vacuum hoses.
Hopefully she runs good, because I didn't want to have to do a tune until after I eventually installed headers...........that is unless Gregg wants to be a good friend and help me tune it in the short game just because.
Alright. after breaking off two easy outs and putting in way too many hours on this thing, we finally got it where I could install the balancer again. I have it 3/4 of the way on with the installer tool and it won't draw up any further. I am putting an amazing amount of torque on the thing with a cheater bar, but I am scarred to go any further. Now what?
Are you using an installer similar to the one in the photo I posted?
