Driving me bonkers
Old Jan 8, 2010 | 01:53 PM
rainbow runner's Avatar
rainbow runner
Cruising
Default Driving me bonkers
Will start at beginning.
Wife driving to work on freeway, car looses power she gets off and takes back road home gets about half way and car will only get up to about 20 mph. End up having it towed.
Get it home start working on it, car won't stay lit. Check fuel pressure, pressured up good but fell like a rock, so replaced FPR. Car starts and idles fine, now for the good part. Car will idle all day long but as soon as I open throttle its like someone choked it. Dies immediately. Restart car, and if I open throttle slowly can get to about 1200 rpm, same thing car dies.
Things I have done so far are
1. tore apart vapor recovery system, line from purge valve to charcoal canister was completely packed with charcoal, clean out line seems ok now.
2. replaced EGR, while checking it with vacuum pump it would open but it would stick when releasing vacuum.
3. Have noticed vacuum is reading low, only about 16 as I open throttle vacuum drops. Checked vacuum in the past and was about 22.
4. Have some scan results on cold engine and hot engine but nothing with car running as i'm waiting on gaskets. Also having problem with scanner, have to jiggle connector to get it to read.
COLD HOT
Coolant temp 55.8 F 201.6
TPS 0.66 volts 0.66
O2 408 mVolts 408
Block Learn 128 128
Integrator 128.00 128.00
Air Idle Mtr pos 160 steps 160 steps
Desired Idle 3187 rpm 3187 rpm
MAP Sensor 4.60 volts 4.68 volts
Manifold Air Tem 55.7 F 163.4 F
Battery Volts 12.0 volts 12.0 volts
Learn Idle Pos 44.00 steps 46.00 steps
Oil Temp 47.7 F 173.30 F
Park/Neutral Detected Detected
Rich Lean Flag Lean Lean
Will get scan while running as soon as I get it back together. Got a feeling will run same as before with vacuum low and choking.
Old Jan 8, 2010 | 01:57 PM
3D-Aircrew's Avatar
3D-Aircrew
What year vette?
Old Jan 8, 2010 | 01:58 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Are your injectors consistently ohmd and pulsing?
Old Jan 8, 2010 | 01:59 PM
rainbow runner
Cruising
Old Jan 8, 2010 | 02:10 PM
rainbow runner
Cruising
Excuse me for being stupid but that just went over my head
Old Jan 8, 2010 | 02:21 PM
onedef92's Avatar
onedef92
You may have leaking injector(s). You should run a pressure test. Also, no pulse signal to injectors can mean a bad injector relay or PCM driver circuit.
Old Jan 8, 2010 | 02:24 PM
pappy.72's Avatar
pappy.72
Could it be a clogged cat?
Old Jan 8, 2010 | 02:31 PM
runner140*'s Avatar
runner140*
I,ve got a 96'.....and when it did that, it was the fuel pump. It gave a code that was a fuel pump clue. Good luck
Old Jan 8, 2010 | 03:08 PM
rainbow runner
Cruising
Just ohmed injectors, all 8 of them read 16.3 to 16.4. Not sure how to pressure test, not sure I would need to as it idles rock steady.
Old Jan 8, 2010 | 03:09 PM
rainbow runner
Cruising
Not sure how to check quickly. Any ideas
Old Jan 8, 2010 | 03:10 PM
rainbow runner
Cruising
Fuel pump pressures up to 42 stays at 39 while engine idling when I increase rpm's to 1200 just before it chokes, pressure stays steady.
Old Jan 8, 2010 | 04:11 PM
vette079's Avatar
vette079
Have to jiggle connector to get it to read.
Is the (dust) cap missing over the ALDL?
In that case a prev. owner might have been reading codes to once in a while.
Reason I mention this is, when you are a little careless with the ALDL connector, the small pins in it can retract (pushed back in the connector).
On my ´91 the cap is still there, but I had the same problem with a scanner, just to find out after a closer look that the top right pin (A) was pushed back quite a bit.
In such a case you can take a pair of small pliers on the back side, to hold a wire in place when you push in the scanner´s connector.
Temporary solution of course.
Might be a tip for those that have problems with their scanners mal- or not functioning.
Old Jan 8, 2010 | 04:38 PM
rainbow runner
Cruising
Just checked ALDL connector. Has female receptacles. Held 3 wires used by scanner (EZ-SCAN 6000) to make sure they are connecting, still says "Vehicle not responding", if I jiggle it around a while it will connect but its a PIA.
Fed-Ex just showed up, so going out to replace all the plenum gaskets so I can fire it up and see if I can get a closed loop scan.
Old Jan 8, 2010 | 04:49 PM
vette079's Avatar
vette079
Yes, they are female, I´m here in Europe, so couldn´t come up with anything better than "pins".
I think we have the same scanner.
AutoXray, isn´t it?
Took a few turns (taking out the batteries, and start all over putting in the right info like GM, vin 8, year and so), don´t know what I did, but I got it working in the end.
Be sure you go by the book (scanner), so you connect the scanner to the ALDL in the right order, that can mess up things.
Are all the sensors still connected in the car/engine?
If you have the engine apart, and disconnected some connectors, it won´t work of course, guess you know that.
Old Jan 9, 2010 | 03:16 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I'm thinking that your on to something here.
When the throttle is opened, vacuum will increase fuel pressure.
This increases fuel flow to assist acceleration. IF vacuum is reading low, the mixture leans rather than enrichens.
I'd start looking for a vacuum leak. Might try plugging some of the larger hoses for testing purposes.
Good luck
Old Jan 9, 2010 | 01:03 PM
rainbow runner
Cruising
Thanks for the hint on removing batteries and starting over on scanner, seems to work fine now.
Old Jan 9, 2010 | 01:05 PM
vette079's Avatar
vette079
Cool, keep us posted on the progress.
To Driving me bonkers
Old Jan 9, 2010 | 01:41 PM
96z51's Avatar
96z51
Good luck
um.. vacuum drops as the throttle blades open.
Old Jan 9, 2010 | 02:31 PM
rainbow runner
Cruising
Pappy.72 just checked exhaust pressure per the book at the air pipe after removing the check valve. Think you nailed it pressure 7 p.s.i., revs like it should. Know of any way to gut the cats till I can replace. That way I can at least use the car. Also any ideas on CAT system, I'm in California so got to have. Only need front half as I have a BORLA system in back.
Old Jan 10, 2010 | 02:39 PM
MK 82's Avatar
MK 82
Actually you got it backwards. When vacuum drops, the press rises app 5 PSI. Watch what happens when you remove the vacuum line to the FPR. That small press change will not cause what the OP describes.
Good luck
