high idle cold
Old Jan 10, 2010 | 08:46 AM
Lewlinda1199's Avatar
Lewlinda1199
Cruising
Default high idle cold
Here is one for you all. My 87 has started to act up. It will idle 500-600 RPM cold and stumble. As it warms up the idle increases. When fully warm it idles 1600. I have check and repaired vacuum leaks. It was intermitent for a while. If I disconnected the battery to clear the ECM it would be fine,now it is all the time. Idle Air Motor?
Old Jan 10, 2010 | 09:06 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Vette
What codes are you clearing?
Mike
Old Jan 10, 2010 | 10:33 AM
Lewlinda1199
Cruising
The best part is after checking codes, there are none just 12-12-12-12
Old Jan 10, 2010 | 11:26 AM
95BLKVette's Avatar
95BLKVette
What weight oil are you using?
When was the last time you changed you IAC motor and also the air filter?
Old Jan 11, 2010 | 05:19 AM
Lewlinda1199
Cruising
We bought the car in March '09 , changed the oil right away I believe I used 15/40 . We don't drive it in the winter. I never changed out the IAC motor. The air filter looked almost new.
Old Feb 22, 2010 | 11:45 AM
surfer92's Avatar
surfer92
The vette should run 5w-30, 15w-40 is to heavy.
Old Feb 22, 2010 | 11:52 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Take the IAC out and give it a good cleaning with carb cleaner. Also clean the throttle body good. That is a no cost test and should give you an idea if it is bad. Don't assume it is the IAC until you try this.
Old Feb 22, 2010 | 11:53 AM
RetiredSFC 97
15 40 is probably too heavy for your neck of the woods.
I run 10 30 in my L98. The first number is for start up the second is for warmed up engine.
look at your book and do what it says to do. JMO
To high idle cold
