Would someone be so kind as to measure from the center of the distributor to the TPI Plenum/TB mount? (Feel free to estimate the center and measure without removing the dist cover, a 1/4" isn't going to be that critical)
I'm building a plenum for my SP intake and I know I need to be less than 9.1 inches above the front china wall and this measurement will make sure I get it in the right place fore/aft.
What intake.?
Be sure to allow for TB to thermo housing clearance.
My Victor E ( Air gap design ) restricts how low the TB ( consequently the plenum) can go if a thermo housing is used because the base of the housing is 2" higher than TPI one.
Kens80v had to do this mod to get clearance on the E intake with custom Nitrous Outlet plenum / elbow http://forums.corvetteforum.com/1572285501-post13.html
Fine if fitted to a LT1 with no coolant outlet
It's a converted 18* high rise (Edelbrock 2959) so space is very limited. I definitely planned on adding an outlet to the front of the coolant crossover to use that t-stat housing.
It looks like I may even have to trim the coolant crossover down a little bit to make room for the IAC valve, we'll see...
