Help w/cluster pics enclosed
Old Jan 16, 2010 | 01:47 PM
tblt44's Avatar
tblt44
Default Help w/cluster pics enclosed
I have 2 pics showing my dim LCD numbers
Do you guys think I need a new cluster or could it be something else??
I don't wana throw money at this problem but do need to see my numbers
Today is a cloudy day,on a sunny day or at night I can't see the LCD numbers at all.
sorry about the flash,I couldn't figure out how to turn it off on my wifes camera
Old Jan 16, 2010 | 02:05 PM
dpd3672's Avatar
dpd3672
I have the same problem on my '93, although mine's a bit worse, I can't see my numbers at all.
From what I could find searching these forums and the internet, it's either a bad connection to the instrument panel or the panel itself is just bad. They apparently fade over time until they're unreadable.
I've seen rebuild service offered in various catalogs for about $300, and used ones on Ebay for $50-200. I'd try the connections first, and if that doesn't fix the problem, you're pretty much stuck with used or rebuilt.
Old Jan 16, 2010 | 02:23 PM
engle1147's Avatar
engle1147
Your LCD panel has UV burn. You live in the "Sunshine (UV) state" according to your profile. I'm guessing the car spends/has spent a good amount of time exposed to the FL rays. The 90 and Up C4 clusters are shaded better by design than the pre 90's versions so they are less sucseptible to UV burn...unless you have a convertible of course. Your best solution is a new LCD panel. In the future, if the car must be parked out outside/exposed to a UV source throw a towel over the cluster to protect it from the UV.
Old Jan 17, 2010 | 08:30 AM
tblt44's Avatar
tblt44
thanks guys
I was looking at used ones but don'twana buy one with the same problem
Old Jan 17, 2010 | 02:39 PM
dpd3672's Avatar
dpd3672
I found this link on the CAC forum. It's probably NOT the problem you're having, but the disassembly instructions and photos may help a little:
http://www.corvetteactioncenter.com/...9/008/article/
Old Jan 17, 2010 | 04:59 PM
tblt44's Avatar
tblt44
thanks for the link this may be of some help.I can't do any damage I may take it apart and play with it all I can do is break it more than it already is.I'm gona buy a new one anyways
To Help w/cluster pics enclosed
