Oil Temp
Old Mar 5, 2002 | 05:25 PM
Nyvette's Avatar
Nyvette
Default Oil Temp
Does anyone know the average operating temperature for the oil of an L98,
mine keeps rising and can get up to 230F which seems kinda high to me.
Old Mar 5, 2002 | 07:13 PM
jpee's Avatar
jpee
Default Re: Oil Temp (Nyvette)
That dont sound too bad.. I have an LT1 & if I'm on the interstate at 70+ for long drives mine will go to 195 - 200
Old Mar 5, 2002 | 07:20 PM
Justin1984's Avatar
Justin1984
my L83 runs about 230-232F. I thought that was OK...it has to at least be hotter than 212F to burn off all the water vapor in there.
Old Mar 5, 2002 | 07:39 PM
VetteNoob's Avatar
VetteNoob
Default Re: Oil Temp (Justin1984)
Mine goes to about 200-210 '86 L98E
Old Mar 5, 2002 | 07:48 PM
vader86's Avatar
vader86
Default Re: Oil Temp (VetteNoob)
230 is a tad warm. These cars were made to run hot from the factory, so you shouldnt be too alarmed by that. However, it really is too hot for the engine to get it up to 230F. So, install either a 160 or 180 thermostat, a fan switch, clean off the front of your radiator (theres alot of dirt cloggin it up), and think about getting someone to burn you a chip to make your fans come on sooner. The immediate thing you might want to do is be sure youre running synthetic oil, it can take that high temp much better.
Old Mar 5, 2002 | 10:12 PM
Nyvette's Avatar
Nyvette
I am just about to change the oil, maybe I'll try the synthetic oil. I already have a 180 degree thermostat installed.
Thanks for the feedback
Old Mar 5, 2002 | 11:49 PM
Lone Ranger's Avatar
Lone Ranger
Actually, 180+ degrees for a sustained run will remove moisture. 180 is regarded as the target temp to stay above in order to remove moisture :)
Old Mar 5, 2002 | 11:52 PM
Lone Ranger
Default Re: (Nyvette)
Holy Coefficients of Friction, Batman!... You're not already running synthetic? :eek:
Dump that Dino juice and put in some Mobil 1 asap! :yesnod:
I bet your oil temp might come down some with Mobil 1, just maybe...
[Modified by 95_C4_convertible, 9:54 PM 3/5/2002]
Old Mar 5, 2002 | 11:57 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: (95_C4_convertible)
Don't worry till you get over 250, the car will tell you when it's getting too hot, and I don't mean by dying! There is supposed to be some kind of warning(on LT1 anyway)
While in FLA last month, I had temps up to 249 from sitting in traffic, coolant got up to 230.
Mobil 1 is supposed to be good up to 300 degrees.
To Oil Temp
