shift kit?
Old Jan 21, 2010 | 09:29 PM
mikeyboy's Avatar
mikeyboy
Cruising
Default shift kit?
i got a stock 1987 corvette with a auto i want to start doing some lil mods to it what is the best shift kit for it to make a firmer hearder shift i have to do a tranny service any way so i figer why not
Old Jan 21, 2010 | 11:29 PM
Vetster88's Avatar
Vetster88
I just had my trans rebuilt with a B&M shift kit. Nice firm shifts while cruising around, and it'll snap the 315's loose when you get on it!
A shift kit will certainly help you find worn out parts in the drive-line It's a great upgrade in my book!
(A LOT of guys suggest the trans-go... Be warned that it can break hard parts.)
Old Jan 22, 2010 | 01:31 AM
qws's Avatar
qws
Usually its between the Trans go and the B&M. Trans go is a bit smoother than the B&M. I use B&M in mine have am pleased with it.
Old Jan 22, 2010 | 10:12 AM
383vett's Avatar
383vett
Transgo here.
Old Jan 22, 2010 | 10:19 AM
RocketSled's Avatar
RocketSled
Trans-go here...it comes with a number of springs to set the clutch application rate. I picked the hardest shift....if I did it again, I might pick the next spring down. I suspect the problem is that the motor is still up around 1800-2000 on startup when I put it in drive. If I wait til the motor slows down to 1000 rpm or so, that first application isn't quite as dramatic.
To shift kit?
