coolant hose bypass
Old Jan 24, 2010 | 07:30 PM
1stL98's Avatar
1stL98
Default coolant hose bypass
hey guys im new here and proud to join u guys in the vette world.has anyone blocked of the coolant hose to the tb and gained anything?
Old Jan 24, 2010 | 07:42 PM
RocketSled's Avatar
RocketSled
I've blocked it. You won't gain anything. There's little fiddly things that are 'power adders' and there's real things that are power adders. The throttlebody bypass is a 'little thing'.
Your butt-o-meter will not be able to tell the difference.
Old Jan 24, 2010 | 07:52 PM
John A. Marker's Avatar
John A. Marker
There is no HP gain. There are advantages....if you work on the car yourself. You can pull off the TB without having to worry about coolant. The same is true if you have to pull the plenum and things below.
You will get a little cooler air into the TB and plenum, but it will not be measurable.
Old Jan 24, 2010 | 08:04 PM
1stL98's Avatar
1stL98
thanks guys.ive been meaning to block it.now i will
Old Jan 24, 2010 | 10:51 PM
John A. Marker
You do not actually block off the hose. There is a inlet on the TB on the drivers side and an exit on the passenger side. Take both hoses off and use a pipe to couple them together. At least on my 85 this hose leads to the heater. It is likely the same on other years as well. You can leave the fittings on the TB uncapped, it will be okay.
Old Jan 25, 2010 | 04:31 AM
blackozvet's Avatar
blackozvet
as above from John, get a double ended 5/8" brass fitting and 2 hose clamps and join the 2 TB heater hoses together. i did mine then drove it and didnt notice any SOP difference, however the next time i drove the car it was hot, over 100F, driving down a 80 kph (about 50 mph) road with lots of traffic lights so driving it easy (no air con either !) i noticed the mileage went from a best of 12.2 litres per 100k to 11.2, which converts to 21 mpg, i have had the car over a year and it had never got better than 12.2.
Old Jan 25, 2010 | 10:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If your going to bypass it, I suggest you buy a longer piece of hose and route it somewhere, other than over the valve cover. Less chance of leaks and not an eye sore.
Old Jan 25, 2010 | 12:02 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I agree, it will only take about 4' of hose to route it around the outside of the engine. A few large black tie wraps help hold the new hose along it's route,
To coolant hose bypass
