Smoking Brakes
Old Jan 27, 2010 | 03:22 PM
Baron515's Avatar
Baron515
Cruising
Default Smoking Brakes
Went for a drive the other day to test out the new Bosch3 fuel injectors I just installed. The car was driving much better with the new injectors.
Towards the end of the drive I started to notice smoke coming from the car when Id stop at a red light, I first thought it was something to do with the new injectors, and the car being badly tuned, and was coming from the exhaust.
Drove home slowly, and when got home tried to figure out what was happening, and found smoke still coming from the front left brake.
First thoughts were either, the brakes were sticking, or there was an oil leak. I took apart the calliper and did not find a problem, though the calliper is quite dirty.
Brake is still smoking after I drive it. Any suggestions on what to do?
Old Jan 27, 2010 | 03:41 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Do you have the factory rubber hoses on it still? The rubber deteriorates over time the inside of the hose will collapse and act like a check valve. It will let fluid into the caliper to close it but it wont let the fluid out and the caliper stays clamped on the rotor. I had this happen on more than one car.
Old Jan 27, 2010 | 04:34 PM
firemanjim's Avatar
firemanjim
Old Jan 28, 2010 | 09:06 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Kubs is right, and you should take out the pads to check for glazing. If they got that hot the pads are probably glazed over and need to be resurfaced before using them again.
Old Jan 28, 2010 | 09:45 AM
Jamesnns's Avatar
Jamesnns
I'm so sorry about this, but the title of the thread makes it so I just can't resist.
If your front brakes are smoking, you could try the "patch" available at any Walgreens store. I know it'll be hard, but the patch comes with a support number for additional help.
Any respect I had was just blown with this post.
Sorry, Thursady am and way too much coffee..
Old Jan 28, 2010 | 05:06 PM
Baron515's Avatar
Baron515
Cruising
Thanks for the help. You're right the hoses seem like the originals. Not much has been changed on this car.
Will add it to the list of things to buy for the upcoming rebuild. Gonna start tearing it down in a few days.
Old Jan 28, 2010 | 06:30 PM
desertmike1's Avatar
desertmike1
When you say "took apart the caliper" are refiring to removing the piston, and cleaning the caliper bore really good, and then replacing the caliper O-ring.
Or just cleaning the exterior of a really dirty Caliper...
Old Jan 28, 2010 | 10:31 PM
pletzvet's Avatar
pletzvet
ditto - and I've also seen a brake hose close up due to compression where it goes through a rusty hose mount/bracket. Not likely that this will be the case on a 'vette with minimal exposure to corrosion, but something to look for.
Old Jan 28, 2010 | 10:44 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
um slow down on the go pedal, and you don't need so much whoa pedal....
Old Jan 28, 2010 | 10:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
Coudl also be a bad caliper thats not releasing all the way. Used to have a javelin SST that, if you used any more than moderate brake pressre they fronts would lock up. Kinda funny watching it go down the street, rear tires smoking and front tires skidding, with a 401 is was the burnout king Nothing like a $400 pos you dont care about.
Old Jan 29, 2010 | 04:54 AM
Baron515's Avatar
Baron515
Cruising
I removed the pistons and gave the whole thing a really good clean. Did not replace the ORing or the boot as I dont have parts easily available to me, but they were not in very bad shape. The hose was very soft though and did suspect, the help here confirms that it probably is the reason.
As im tearing the car down soon, and want to rebuild whole car to good health again, I will be rebuilding or replacing all the callipers based on my budget. So will be getting everything sorted soon im hope
To Smoking Brakes
