Idle issue solved
Old Jan 28, 2010 | 08:53 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Default Idle issue solved
Some of you know I have been having a couple issue lately. I first have a fuel pressure drop off issue. Pressure goes up to about 47 and then falls like a rock. Then all of a sudden, well not really all of a sudden, I have a no idle issue.
I couldn't complete the fuel pressure test adequately until I got the idle issue resolved. I at first thought they may be related but I then decided they were a separate issue. I narrowed it down to the IAC.
Well I ordered a new IAC yesterday and picked it up today. Guess what? It was the wrong one. So I called them and after they calmed me down they ordered a new one.
So I said the heck with it. I got the carb cleaner out and cleaned up the old one and put it back in. The dang thing now idles. It isn't 100% but it does idle at what I would consider 75%. So the thing still isn't working properly but I know what the issue was.
So tomorrow I will install the new IAC and see if that totally cures it but from all indications it should as it is now idling with a cleaned IAC.
I hope this helps someone in the future if you ever should do a search and come across this thread. You may PM me to speak directly to me and I will give you my phone number!!
I will come back tomorrow and give an update.
Now back to that pressure thing!
Old Jan 28, 2010 | 10:25 PM
cumbercr's Avatar
cumbercr
It's always good to hear success stories. I've been fighting idle issues forever. A new IAC didn't work for me.
Old Jan 28, 2010 | 10:40 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Be sure and clean the housing the IAC goes into real good too. That's where most of the crud is anyway.
Old Jan 28, 2010 | 10:48 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
If you are having a couple issue, shouldn't u see a marriage counselor? or maybe a viagra doctor?
Hey, I just read em...............
Old Jan 29, 2010 | 08:45 AM
RetiredSFC 97
Not in this instance. My couple issue is me and my vette. That is what I'm working on.
Old Jan 29, 2010 | 09:03 AM
WW7's Avatar
WW7
Just make sure you set the IAC before you install it , if its not already set..The pintle can't be out to far or you will damage it when you install it..I believe the setting is (28mm) out, but check to make sure. Below is a copy of the FSM install procedure for a 90 Corvette in case you need it.. .WW
http://forums.corvetteforum.com/atta...90-l98-009.jpg
Old Jan 29, 2010 | 11:06 AM
RetiredSFC 97
Yes I will set it.
thanks
Old Jan 30, 2010 | 07:37 PM
RetiredSFC 97
Installed the IAC today and it did fix my idle issue, so you all know
these were my symptoms.
When I cranked it, it would not start. If I gave it the slightest bit of throttle it would fire up and run like a champ. In the beginning if I kept throttle it would eventually work itself out. But then it got to where it wouldn't idle period. Like I said if I gave it slight throttle it would run great and it ran great on the highway.
When I took the IAC out the pintle was fully extended and I didn't think that was right, and it wasn't. It is my understanding they contract so that air will flow immediately upon crank and start.
So there you have it if anyone has these symptoms now or in the future.
Old Jan 30, 2010 | 09:10 PM
WW7's Avatar
WW7
Isn't it nice when things work out!!!.....WW
Old Jan 30, 2010 | 09:57 PM
pletzvet's Avatar
pletzvet
Nice to see that you found a solution, SFC.
Old Jan 31, 2010 | 10:23 AM
Midnight 85
Thank you for letting us know the fix.
Old May 1, 2010 | 04:31 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Sorry to revive the thread. But did you ever put an ohm meter across the IAC terminals to see if it was bad?
http://shbox.com/1/iac2.jpg
To Idle issue solved
