Transmission problem solved!!!!! WOOHOO!!!
Old Mar 6, 2002 | 04:28 PM
GlockLT4's Avatar
GlockLT4
Default Transmission problem solved!!!!! WOOHOO!!!
Finally, my luck is turning around. I had a good job interview today and I just called and found out what the problem is with the transmission. It was the Manifold Pressure Switch that was keeping it from shifting into third. After taking the entire transmission apart again looking for a reason for it not working and coming up empty handed, he started to question the pressure switch. He took the pressure switch out of mine and put it on their "test dummy Z28" and it wouldn't shift into 3rd either! Problem found :D ... so he picked up a new one for $37 and he's going to finish putting the valve body on tonight and he said pick it up in the morning ... WHOOHOO (and he guaranteed me it would be ready tomorrow morning, so I will be there waiting until he gets it done if he doesn't get done tonight like he said he would).
Finally, I may get to drive my car again!
[Modified by Glock'94, 2:34 PM 3/6/2002]
Old Mar 6, 2002 | 04:31 PM
pablocruise's Avatar
pablocruise
Default Re: Transmission problem solved!!!!! WOOHOO!!! (Glock'94)
Absolutely fantastic man! Finally some good vibes. Keep'em comin'!
Old Mar 6, 2002 | 04:36 PM
bwagner's Avatar
bwagner
Default Re: Transmission problem solved!!!!! WOOHOO!!! (89 Paul in cal)
Mine was doing the same thing, and I've had it back to the guy 5 or 6 times now from it doing the same thing over and over again. I hope yours doesn't keep going out like mine did! I've but more money in to my trany that I could have bought a brand new one by now. Reading how cheap yours was shows me that I was taken for, 5 or 6 times!!!!!! :mad :mad :mad
Old Mar 6, 2002 | 04:44 PM
GlockLT4's Avatar
GlockLT4
Default Re: Transmission problem solved!!!!! WOOHOO!!! (bwagner)
Your manifold pressure switch has gone out 5 or 6 times?!?!?!
Old Mar 6, 2002 | 04:47 PM
scorp508's Avatar
scorp508
Awesome. Now be gone with yourself and your torque makin' momma!! I wanna see BIG clouds. :D
Old Mar 6, 2002 | 04:52 PM
bwagner's Avatar
bwagner
I don't know if it was the mainfold pressure switch, but mine was doing the same thing and not going into third gear. There was a few times when it would go out on me that it would go from 1st to 2nd to neutral and just rev up. Don't know if that's going to be the same issues or not...
Old Mar 6, 2002 | 04:58 PM
88_vette's Avatar
88_vette
Really glad to hear glock. I hope this is it on the bad luck for you and all up down hill from hear down hill meaning things are easy.
Old Mar 6, 2002 | 05:50 PM
Nathan Plemons's Avatar
Nathan Plemons
You know you could solve all of your problems, including interior resonance if you had a 6-spd. I'll make a deal with you, you just send me your 383, I'll send you in return a Hot Cammed 350 with a T56 Camaro 6-spd, along with none of the stuff required to make it bolt up.
Sound like a plan?
Old Mar 6, 2002 | 05:56 PM
bwagner's Avatar
bwagner
Default Re: Transmission problem solved!!!!! WOOHOO!!! (Nathan Plemons)
Should I send it Ground or Over night? :lol:
Old Mar 6, 2002 | 06:22 PM
GlockLT4's Avatar
GlockLT4
Sound like a plan?
:p: :p:
Old Mar 6, 2002 | 11:22 PM
FSTRNU's Avatar
FSTRNU
This sounds promising since you are getting yours back tomorrow maybe I can get mine back together this weekend.
Old Mar 7, 2002 | 06:06 AM
NoWorries's Avatar
NoWorries
:cool: :cheers:
Old Mar 7, 2002 | 09:33 AM
StephensblackL98's Avatar
StephensblackL98
Outstanding, Curtis! Dang, you have a very near-new Corvette, now! Best wishes on the job thingie, too. Good things do happen to good people.
Old Mar 7, 2002 | 10:20 AM
TrplBlk01's Avatar
TrplBlk01
I know the feeling. I've not had mine for about 3 1/2 weeks now due to the motor rebuild. The machine shop is laggin big time. :mad
To Transmission problem solved!!!!! WOOHOO!!!
