dual mass flywheel
Old Jan 30, 2010 | 10:45 AM
joebuckSR's Avatar
joebuckSR
Default dual mass flywheel
What is the explanation of a dual mass flywheel?
Old Jan 30, 2010 | 12:02 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
IIRC its two masses with springs keeping them in line and a rubber compund that keeps them together and can stretch.
Also made of unobtanium - very hard to find.
Old Jan 30, 2010 | 12:11 PM
desertmike1's Avatar
desertmike1
"Google"
Old Jan 30, 2010 | 08:33 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
it's basically a flywheel with a shock aborber to prevent gear chatter
Old Jan 30, 2010 | 10:14 PM
rodj's Avatar
rodj
Originally Posted by desertmike1
"Google"
http://www.luk.com/content.luk.de/en...zms_lv_new.jsp
Old Jan 31, 2010 | 12:28 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Jan 31, 2010 | 01:58 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Good links to what a DMF is. The reason it's in our Corvettes has to do with GM's search for a viable 6-speed stick to put in the ZR1.
I don't remember the exact story, but they had to use the German-built ZF6 as the only 6-spd platform available (at the time) that would handle the necessary power (and more). Because of the geometry of bearings/gears INSIDE the ZF6, rattling/noises are present w/o the use of a dual-mass flywheel.
So, GM opted to use one in order to address/prevent objections they expected -- had they used a SMF.
Old Jan 31, 2010 | 10:38 PM
dizwiz24's Avatar
dizwiz24
something that should be removed to save weight!!!
Replace w/ aluminum fidanza flywheel and sprung hub clutch.
Old Feb 1, 2010 | 02:34 AM
GREGGPENN's Avatar
GREGGPENN
This has been an editorial comment. But, it does not necessarily express the views of management!
Seriously, if you do convert to a SMF, make sure to use a sprung hub clutch. There's at least one guy here who didn't. He's in the process of converting to an automatic because of his disappointment in the ZF6. Says he got tired of shifting in traffic -- but the writing's on the wall IMO.
FWIW: Carolina clutch says the heavier steel SMF provides a more drivable option. The momentum of that extra weight helps aide/ease clutch engagement w/o killing the motor.
There's advantages to each option though. Lighter rotating mass makes for a faster revving motor. The momentum of a heavier mass keeps the motor running (rotating) while letting the clutch out.
To dual mass flywheel
