New guy with a question
Old Jan 30, 2010 | 08:25 PM
87sdvette's Avatar
87sdvette
1st Gear
Default New guy with a question
I have an 87 with plenty of wear and tear on her. currently the ignition switch seems to only work sometimes. Does any have any info that can help me replace the ignition switch?
Thanks,
87sdvette
Old Jan 30, 2010 | 08:30 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
u need a factory service manual.
get one b4 u break something
Old Jan 30, 2010 | 09:20 PM
C409's Avatar
C409
It could be a vats contact issue , pretty common ... and that would require a switch replacement . Its tricky but not impossible , but like coupeguy2001 suggests , get a factory sevice manual first , it will be worth its weight in gold for as long as you own the vette , and will help you diagnose the problem so you will only change the parts necessary to cure your ailments. Don't even think about a Haynes !
Old Jan 30, 2010 | 09:44 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Thanks,
87sdvette
Welcome nOOb. Post up some pics of your vette.
Its VATS related. Has to do with the little pellet in your key. Do a search on VATS and you will be able to read for days about VATS.
Corvette Mike
Old Jan 31, 2010 | 10:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Thanks,
87sdvette
When you say "seems to only work sometimes", do you mean, sometimes you are able to rotate switch, or sometimes the engine cranks over ?
These links to my FSM, may answer both.
http://members.shaw.ca/agent86/Steering%20Column.pdf
http://members.shaw.ca/dankai/Park%20Lock%20Cable.pdf
http://members.shaw.ca/dankai/Vats%20Electrical.pdf
Old Feb 3, 2010 | 07:18 PM
davemeg's Avatar
davemeg
Finally a chance for me to contribute rather than just benefit...
My 87 would not crank - usually when it was hot outside. There's a great thread on the C-4 forum titled something like "VATS" or "No Crank" and in that thread are detailed instructions on how to bypass the VATS system. I followed that advice (after trying other stupid newbee stuff) and have not had the problem since. Of course that was my issue, your mileage may vary and you should get the real manual as suggested.
This is a great forum with awesome help available, these pros even tolerate my most stupid questions! I'm honored to throw my 2 cents in to help someone!
To New guy with a question
