94 Fuel filter location
Old Feb 1, 2010 | 04:59 PM
fastcw's Avatar
fastcw
Default 94 Fuel filter location
Where is the fuel filter??
UPDATE: Job finished, here are a couple of hints.
Move the starter out of the way, takes less than 5 minutes, and is worth the time. Just two bolts, and the battery connection to remove. Leave the other wires connected. Then you can reach through where the starter was, over the catalytic converter, and access the front connection on the filter. Also makes it easier to get at the bolt that secures the filter clamp to the frame.
There is a plastic clip under the passenger door that secures the fuel lines to the frame. Take the 10mm nut off the clip mounting stud and pull the lines free. That will allow enough movement in the line at the rear of the filter to pull it back and free of the filter.
Old Feb 1, 2010 | 05:11 PM
xole's Avatar
xole
Passenger side frame rail (kind of by the cat). Do a search there are a lot of hints and procedures since it is in a hard spot and also the line is pressurized.
-D
tblt44's Avatar
tblt44
passenger side inside frame rail just below the exhaust manafold.I'ts a pain to change if it's too tight.Pull it up thru the engine bay as a last resort.
To 94 Fuel filter location
