Suspension Overhaul
Old Mar 20, 2012 | 04:26 PM
  #41
rfn026's Avatar
rfn026
That makes sense to me. I just don't see a lot of C4 race cars with the Vette Brakes bracket. Every racer knows about the DRM bracket. That sort of solved it for me.
Richard Newton
Old Mar 20, 2012 | 07:06 PM
  #42
USAsOnlyWay's Avatar
USAsOnlyWay
Yeah, if you have heims it is really easy to just make your own setup, no need to buy a bracket. But the DRM solves the problem I have with those square adapter plates which place the bolt in the center of the adjustment range. With the 84-87 or 88-96/VBP brackets you will not get the same drop as you would welding a washing at the bottom of the slot. With the DRM setup it looks like you will not lose height either way.
So... 84-87< 88-96 /VBP < DRM =/< Custom
Old Apr 28, 2012 | 12:50 PM
  #43
rfn026's Avatar
rfn026
Speaking of C4 rear suspensions here's a bracket from the old World Challenge days. Yes it's legal.
Instead of having two brackets for the lower camber rods they used a single bracket.
Richard
Old Apr 28, 2012 | 12:59 PM
  #44
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Richard
I like that one.
