Suspension Overhaul
Old Feb 1, 2010 | 06:24 PM
Alan777's Avatar
Alan777
Default Suspension Overhaul
I've ripped Z51 springs and shocks out of a
n 88' to put in my car. While Im replacing them, I was considering replacing all the bushing, and possibly changing out the sway bars. I have a base model 88' Auto, and It's basically a summer DD/drag/autox car.
I saw THIS. I know Poly bushings will help stiffen the ride a little, and I've also been told to properly lubricate before pressing them in.
ANyone have any first hand experience/advice? I have heard a few negative remarks about going full poly bushings, and I wanted to make sure it was a worthwhile investment before i pulled the trigger.
Old Feb 2, 2010 | 08:03 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
It depends on what you want from the car. Those that want to tighten up the ride and are ready to deal with the increased suspension stiffness like them. If you live in an area that has decent roads (not in the snow belt) you would probably be fine driving the car. We also carry a full car kit, on our website. Call if you have any questions.
800-442-0335
Old Feb 2, 2010 | 08:18 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If you go poly get lots of extra grease.
I did all but the batwing bushings 0n my 92 a year ago with the energy suspension bushings and I have no complaints.
Old Feb 2, 2010 | 08:34 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Did mine in my 93 this past year with energy suspension all good.Drill holes in old ones to remove them easier.
Old Feb 2, 2010 | 10:54 AM
Alan777's Avatar
Alan777
Thanks for the responses guys, I'm not to worried about how harsh the ride as anyways, I have another car if I get sick of it.
I can't stand squat and roll, and I've been told poly bushings are a fairly inexpensive way to tighten everything up.
Now for my last question. Im guessing these bushings are a tight fit, how are you guys pushing/pressing the bushings in? and what type of grease should i use?
Old Feb 2, 2010 | 02:11 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
I got a Harbor Freight ball joint press (looks like a big C-clamp)
With it, drill pits. hack saw, dry wall saw I was able to get all the old bushings out.
The only bushing that was difficult to put back on the car was the rear arms from the dana to the knuckle. It was only the dana side that gave me trouble.
With the grease and the two piece bushings it was not that hard to put them in.
I had to buy the two sway arm kits to match the size of my sway arm. The hard ones were on the end of the sway bar.
Old Feb 2, 2010 | 07:52 PM
blackozvet's Avatar
blackozvet
I did my whole car front and rear last year, using the red Prothane from Summit and black Energy for the sway bars and replaced all ball joints at the same time. Huge difference, really tightens the car up. Some people say dont use the red coz it squeeks but i have had no issues, just follow the instructions on lubing, only put the lube between the outside of the metal sleeve and the urethane, they have machined slots in them so you know where to put it, and dont put it anywhere else.
Old Mar 6, 2012 | 05:30 PM
GMAN1953's Avatar
GMAN1953
800-442-0335
Your, "Corvette Parts Online" link does not work for me, the other links on your web site work....
G
I live in Western Michigan
Old Mar 6, 2012 | 07:53 PM
Alan777's Avatar
Alan777
I'd probably private message him, this thread is old.
Old Mar 6, 2012 | 09:30 PM
gunnerjuju's Avatar
gunnerjuju
800-442-0335
think he meant
http://www.muskegonbrake.com/corvett...-total-car-kit
Old Mar 7, 2012 | 03:58 AM
GMAN1953's Avatar
GMAN1953
Thanks Alan!
Old Mar 7, 2012 | 03:59 AM
GMAN1953's Avatar
GMAN1953
Originally Posted by gunnerjuju
Thanks gunner
Old Mar 7, 2012 | 09:11 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I rebuilt mine with the VB&P Extreme Touring setup. It really stiffened up the car, and the ride height adjustability is very nice. You just have to raise the car up and turn a screw for the front.
Old Mar 7, 2012 | 01:10 PM
mcm95403's Avatar
mcm95403
If anyone is doing poly bushings THIS is the lube to get - it's AWESOME!
http://polybushings.com/pages/bushinglube.html
Old Mar 7, 2012 | 03:49 PM
GMAN1953's Avatar
GMAN1953
Is it stiffer than the Z51?
Old Mar 7, 2012 | 04:22 PM
rfn026's Avatar
rfn026
Keep in mind that the poly doesn't last a long as the OEM product. They do wear out.
Energy Suspension has been very good and we're going to try a harder polyurethane. Delrin is a better choice for a track car. A lot of people use aluminum bushings. That's not a good idea for the street though.
My whole rear suspension needs to be rebuilt. Take a look at this Vette Brakes bracket that I took off the car today.
I think what happened here was the poly bushing broke up on the end of the lower strut rod.
That set off a series of events that caused the entire rear suspension to destroy itself. The interesting thing was the only handling issue was excessive oversteer on the exit.
This is ending up being a complete rebuild.
Richard Newton
101 Projects
Old Mar 7, 2012 | 05:46 PM
Nathan Plemons's Avatar
Nathan Plemons
I put the energy suspension poly bushings in my car several years ago, back when it was a daily driver. It did tighten it up quite a bit. Yes it rides stiffer, but it is a sports car. If I wanted to know what it felt like to drive a sofa down the street I would have just bought a C5.
To Suspension Overhaul
Old Mar 7, 2012 | 05:51 PM
GMAN1953's Avatar
GMAN1953
Wasn't my point, I have the Z51 package which is stiff...was thinking i may need new shocks, only had this car a couple of months, car has 75 K...not sure when the shocks have been changed if at all...
Regards; G
Old Mar 7, 2012 | 06:00 PM
Nathan Plemons
Sorry, I was responding to the original poster. That's before I saw the thread is 2 years old
Old Mar 7, 2012 | 06:05 PM
GMAN1953's Avatar
GMAN1953
Oh crap.....sorry. I'm just looking for as much info as I can get...
Regards; G
