injectors?????????
Old Feb 2, 2010 | 11:30 PM
Jackwmonk's Avatar
Jackwmonk
7th Gear
Default injectors?????????
i traded for this car 2 weeks ago it ran fine for 2 days then started smoking white when warm and the gas smeel was really bad then it stops smoking for a while and then starts again any bsuggestions i pulled plugs they are ok not lossing any coolant im stumped
Old Feb 2, 2010 | 11:31 PM
Jackwmonk's Avatar
Jackwmonk
7th Gear
smoking and smells of gas
Old Feb 2, 2010 | 11:32 PM
Jackwmonk's Avatar
Jackwmonk
7th Gear
i do no know
Old Feb 2, 2010 | 11:34 PM
96z51's Avatar
96z51
i just talked to someone with a very similar issue. no idea whats causing it. fogs out the driveway but seems to be running fine.
Old Feb 3, 2010 | 12:25 AM
Mark85Vett's Avatar
Mark85Vett
I just replied to your PM...you need to get it on a scanner and see what the computer is doing when that happens
Old Feb 3, 2010 | 02:09 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If it is starting to blow a head gasket, I wonder if that's messing with the O2 sensor and causing a rich mixture/gas smell?
Sometimes the lack of seal (from a head gasket problem) will kill the vacuum necessary for antifreeze to pull in from the overflow tank.
Old Feb 3, 2010 | 09:18 AM
surfer92's Avatar
surfer92
WHAT YEAR????????????
OHM the injectors, there is a sticky by FIC about injectors.
Do this while the engine is warm, basically if the fuel injector is under 12 OHM's, replace.
Old Feb 3, 2010 | 09:19 AM
surfer92's Avatar
surfer92
Is it smoking out both exhaust ports?
To injectors?????????
