Is there a seal that slides onto the spindle yoke/axle, before you slide it through the knuckle and through the bearing hub assembly. When I took the axle out there was not a bearing seal, only the washer with the lip on it. In the fsm it mentions a bearing seal but I cant tell if the seal is part of the hub. It seems like there should be a rubber gasket or seal where the hub butts up against the back of the spindle yoke. Hopefully this makes sense to one of you guys. I could not find it at any parts stores or dealerships. Any help would be appreciated. I am so close to being done with this. Thanks
