86 vs 87. Big difference in power?
Old Mar 7, 2002 | 09:52 AM
Jim85IROC's Avatar
Jim85IROC
Default 86 vs 87. Big difference in power?
I've found a couple 86s at reasonable prices, but I'm not too thrilled with the idea of a corvette that's only got 10 more horsepower than my GTA with a 305. How much real world power (Let's forget GM ratings) am I giving up by getting an 86 with iron heads vs. an 87?
1 more question: The 86 still used a hydraulic cam right? Wasn't 87 the first year for the roller cam?
Old Mar 7, 2002 | 10:19 AM
vader86's Avatar
vader86
Default Re: 86 vs 87. Big difference in power? (Jim85IROC)
the power ratings on our years are fairly correct, 230 for 86 with Iron and 235 (i guess) for the 87s.
Old Mar 7, 2002 | 11:17 AM
scorp508's Avatar
scorp508
'87 is 240hp.
A Z51 car in '87 was 245.
Old Mar 7, 2002 | 11:36 AM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
If it's just the alum. heads that you want, take a close look at the '86, the latter cars of the production run wore aluminum heads.
Old Mar 7, 2002 | 12:21 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default Re: 86 vs 87. Big difference in power? (TrueBlue ChevyDude)
no more power just weigh less. iron e-86 vs aluminum
Most L98s run about the same regardless......at least thats my finding after 6-7 years of ownership.
[Modified by SurfnSun, 11:22 AM 3/7/2002]
Old Mar 7, 2002 | 12:22 PM
Jim85IROC's Avatar
Jim85IROC
The first 86 I looked at had iron heads. I've made a note to check. But, it's not just the heads I'm concerned about, it's the overall power. My IROC keeps me VERY busy, so I don't need another mod project. I want turnkey fun. My cousin has a 91 6-speed that's beautiful, but I'm afraid that I'll go broke buying it and won't have money left over for the IROC.
Old Mar 7, 2002 | 12:23 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
All '86 Convertibles and Mid year coupes got the alloy heads the 87's have.The 86 has the hydraulic cam and new one piece rear seal.The 87 has the rollercam.
Power for the 86 alloy heads was 235 hp.87 was 240-245.
A good exhaust system will free up a few more ponies in either car.Also,in 86,GM added dual precats to the front Y pipe with their main cat and is probably a slight restriction in power.The 85's didnt have the precats and had 230 HP.Eliminating those precats is a good mod.
Also, keep in mind torque is improved with a 350 over a 305.
F cars are heavy,I had one,and my Vette stock felt like a rocket compared to many stock F body TPI cars ive driven.
Old Mar 7, 2002 | 12:53 PM
vader86's Avatar
vader86
Default Re: (scorp508)
'87 is 240hp.
what did they do to improve the hp in 87? why is Z51 higher, i thought it was only a suspension package?
Old Mar 7, 2002 | 12:57 PM
Jim85IROC's Avatar
Jim85IROC
Default Re: (vader86)
In the f-body, the addition of the roller cam provided their advertised 5-hp gain. I'd imagine it's the same for the 'vette.
Old Mar 7, 2002 | 01:32 PM
dgoodhue's Avatar
dgoodhue
Default Re: (Jim85IROC)
87 were rated at 240hp vs the 86 aluminum heads 235 (and iron heads 230)
Scorp and other are extrapolating the 5hp gain from free flowing mufflers that Chevy advertised in 88-91. 87 Z51 had these but there was no advertised gain. A 86 aluminum headed Z51, I supose could say there cars have 240hp as they also had low restriction mufflers.
Old Mar 7, 2002 | 03:08 PM
hz900's Avatar
hz900
I have an 86 with the iron heads and the main diff. is the weight. I think the iron heads are about 100 pounds heavier and produce less torque.
Old Mar 7, 2002 | 07:46 PM
87vette's Avatar
87vette
Is this Jimbo ??? :) Who went to RIT ?
Old Mar 7, 2002 | 07:49 PM
scorp508's Avatar
scorp508
As was stated Z51 got the free flowing mufflers. Z51 consisted of more than handling stuff. Handling/cooling/suspension/steering.
Bilstein Shocks
Thicker Swaybars
Tighter Springs
Quick Steering Ratio
Power Steering Cooler
Oil Cooler
Free Flowing Mufflers
9.5" wide rims at all 4 corners
Extra Frame Braces
Longer Front Spoiler
Old Mar 7, 2002 | 08:14 PM
vader86's Avatar
vader86
Bilstein Shocks
Thicker Swaybars
Tighter Springs
Oil Cooler
Extra Frame Braces
well i knew all that, but the exhaust they put on was so different that it gave another 5hp? what was the difference in exhaust systems on the 87
Old Mar 7, 2002 | 08:51 PM
scorp508's Avatar
scorp508
All 4 outlets were fully functional allowing a more free flowing system. Unlike the mufflers with only two functional outlets.
Old Mar 7, 2002 | 09:26 PM
Jim85IROC's Avatar
Jim85IROC
Default Re: 86 vs 87. Big difference in power? (87vette)
That's me... who are you?
Old Mar 8, 2002 | 09:55 AM
dgoodhue's Avatar
dgoodhue
I assume would by now, most every early C4 has replaced its exhuast, unless it is a real low mileage garage queen. (when I was looking at C4's 8 yeras ago every other one had a new exhuast or needed one)
To 86 vs 87. Big difference in power?
