There is no hi-performance timing set for the 92-94 LTX because of the spline drive for the Optispark. No money I guess in a mfgr tooling up to prouduce parts for such a small faction of SBC's.... Espc when even GM dumped the spline drive Opti.
You could do what I did - Which is to convert the car over to a 95-97 pin drive Optispark.
With the Pin Drive Opti you can run any number of double roller chains (elect WP) or the extreme duty (mech drive WP).
The 92 has a few specific things you have to modify that are not required to 93 and 94 Y bodys when changing the Opti drive to the later pin drive set up.
Do a search on my user name - as I just went over them last week for someone else here in C4 Tech.
Will
Will
Ok. I guess i have to do something like that :/ i don´t want the new engine to break just because of a bad camdrive. To bad there is´nt a nice camdrive out there. I did find one thou but i don´t know anything about it.
No clue about that one. $365.00 for a timing gear is more $$$ than doing an entire pin drive conversion... and from the pic you'll still have a silent drive chain.
The TB your looking for is an Arizona Speed and Marine MONO BLADE. I have one on my car and its a first class part.
Will
Cool! Thank you! How are the final finish on the Mono Blade? Does it fit the Lt1/LT4 intake fine beside the matchporting or do i have to mess with the bolt pattern/TPS sensor/throttle cable etc..? I just wonder if it worth the extra to replace my 58mm BBK?
I think i´ll go with the conversion to the LT4 camdrive instead. It feels like a better choise.
Another thing!
I saw that edelbrock has a Lt4 aftermarket intake. I have bought a Lt4 intake for this Lt1 engine because of my AFR #1039´s. But does anyone know if i can get some extras from the Edelbrock version? Or does it run hand in hand with the GM LT4 intake?
Ok i read the thread about Lt4 timing conversion and i have one thing i´m worried about. I just bought this Comp cams custom grind for this engine. But will it fit the Lt4 timing set?
I have taken pictures of the pin and centerhole of the cam,
here you go.
The pin stands out about 14mm ( 0.55" )
And the hole diameter is about the same. Sorry for my low standard of measuring but i was at home and did´nt have the right tools to measure here LOL
Few pics of my AS&M Mono Blade. Bolt pattern, TPS, IAC all fit fine. Throttle linkage (plastic cable cam) was slightly different but nothing some bending on the bracket couldn't fix. As for the machining fit and finish - Judge for your self.
The 58mm Pro Products I had on the car before the Mone Blade.
The modifications you'll need to do a stock LTX intake is you will need to port the throttle opening so it will look like this one which I ported for CF Member blackharleyman.
Will
GM's spec for the Gen II opti camshafts dowel pin is .620, I've read that up to .685 will work. I wouldn't want to go too much below that spec.
Damn! I´m a little short on that one then. What about the hole in the cam? Is that anything that can cause any problems? I can make a new dowel pin at work and replace the one i have, but the hole is a little bit more difficult to do anything about.
Will
WOW Look really nice. Now when you posted pictures from your enginebay i have a question! where did you get the valvecovers? I´ve been looking for covers like those but have´nt found any :/ do they support 1,6 rocker arms and high lifts?
I grinded the block yesterday for the stroker so now it´s time for the engineshop to start working.
As long as i see this outside my window i do´nt need to rush LOL
Another thing!
Thanks.
/Johan.
You need to check the intake port dimensions to be sure the stock LT4 intake will work with the AFR 195's. I know that the Eldebrock LT4 ports are .12" longer that the AFR 195's. In other words the intake ports do not match the afr 195's. I am currently using a stock LT1 intake/afr 195's on my engine build. It would have been nice if the the eldebrock intake would have worked. The air gap is cool looking. It appears that eldebrock made this intake to match up to their LT-4 heads.
The stock LT4 intake will work with the new AFR 195 Comp Port heads, it has the same port dimensions and locations as the stock LT1 intake. The stock LT4 heads have different port dimensions, not the intake.
Allright! Question is! Will the edelbrock intake be a waste of $$$ or do i get some extra ponys using it! I think i´ll might go with the Lt4 intake to start with.
The Eldebrock intake dosen't offer anything performance wise over the GM LT4 except to isolate the runners and plenum. It's just easier to find (as GM stopped mfgr of the LT4 intake). If you already have a GM LT4 intake I'd suggest you stay with it.
STL94LT1 is right. The GM LT4 intake will fit either AFR 195 head with a very little port matching. The LT4 intake I have pics of is one I ported for the 383LT4 w/AFR 195 Comp Port Elims I built for blackharleyman. There are pics in his engine build thread (stickied at the top of C4 tech/performance) of how much material I had to remove from the runners to make it match up. Look in his thread and you'll see it wasn't very much.
My rocker covers are Moroso PN 68326. They will clear roller rockers fine. You will have to modify the drivers side cover to clear the LTX altenator. Below is a diagram with dimensions (listed in inches) and some pics as to how I cut mine up and welded it back.
Will
Thank you Will! That´s some nice information. I´ll stick to the Lt4 intake then. Do you know if the center hole in my camshaft can cause any problems for the Lt4 timing? Or do i just need to replace the pin.
Thanks.
/Svante.
The pilot hole for the later pin drive optispark measures 0.500" dia x 1.0625 deep.
The early spline drive hole measures .450 but it is bored at a taper to .240 at the rear.... I rember how deep it is.
You'll need to measure yours with something more accurate than a ruler to tell the difference.
Most aftermarket cams have the late model straight .500X 1.062 hole.
Will
Will
Yes i know! but i have´nt got all the parts down to the garage yet. No hurry with that. I´ll order the parts i´m short of and then i see what fits and what does´nt nothing i can do anyways. Thank you for the help!!
