hood cable problem
Old Feb 6, 2010 | 05:01 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default hood cable problem
was going to open my hood to put on emergency hood release cables and it happen, pass. side opened but not drivers side not, so i took off a bunch of crap and am able to get my hand 2inches from putting a temp release cable on, have no dexterity in my fingers up in there , hands too big, almost got it , so close but yet so far away. Any ideas?
Old Feb 6, 2010 | 05:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
MAM makes a tool to open the "clam" style hood in such cases.
If you can bend a short "L" on the end of a stiff rod, you can slide it in on top lf the latch, drop it into the latch and rotate the rod to open the latch.
Unless the cable is broken, you could try parking on an incline; the slight body twist might be enough to free a latch that simply doesn't open far enough.
Old Feb 7, 2010 | 11:16 AM
kimmer's Avatar
kimmer
Hey Jim, thanks for the info. went to MAM site saw the tool and made one this morning, popped open the hood in 5 minutes. Thanks again. Kim
Old Feb 7, 2010 | 03:30 PM
runner140*'s Avatar
runner140*
Look like this?
Old Feb 7, 2010 | 04:00 PM
65Z01's Avatar
65Z01
Thanks again. Kim
Kim, you are quite welcome; glad it did the trick for you...
Shortly after I got my C4 in 2000 I had the same issue and that tool is now behind the passenger seat.
Old Feb 7, 2010 | 08:27 PM
kimmer's Avatar
kimmer
Originally Posted by runner140*
Look like this?
mines homemade but looks similar, cant see the ruler increments, what mark is the tape at?
Old Feb 7, 2010 | 08:33 PM
65Z01's Avatar
65Z01
My Vette is in the shop now so I can't measure mine but, as I recall, I set the tape so that it would just touch the large WS block and the "business end" would be in latch.
All you really need is some reference point on the car when the hood is closed so you will know when the tip is over the latch.
To hood cable problem
