Loosen it, or not?
Old Mar 7, 2002 | 12:23 PM
J Z06's Avatar
J Z06
Default Loosen it, or not?
You all know my trans is poofdaa :D. My convertor is a pro torque 2800(on the tighter side of 2800) that has been in there since early '99. Not many passes at the track...but lots of street use(hard runs there too). Now...should I go to 3000 or leave it as is.? The few times I go to the track I WOULD like a better e.t., but don't want to give up how nicely it drives. It's a tough choice.
Tell me what you think. I'm thinking the extra 200 r's isn't that bad.
JD REPLY DAMNIT, don't just look ! :hat
Old Mar 7, 2002 | 12:37 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Loosen it, or not? (JD 90 383)
Hmmm...couldnt tell ya that since converters seem to vary even rated at the same stall speeds.Ill sit back and watch the others chime in and say,and also wonder if with your motor and gears,would increasing more stall be a little too much?
Old Mar 7, 2002 | 12:54 PM
jpee's Avatar
jpee
Default Re: Loosen it, or not? (Bill's86Coupe)
For the amount of time ON track VS time ON street, I'd leave the converter as is..!!
IF you were racing 2 times a month 10 12 times a year, I'd say go with more stall, but you gottta remember you spend 99% of your time on the street!
Also GET that cooler, & me & ralph will get it in for you...ESPECIALLY with the new trans,
remember HEAT KILLS transmissions...
Old Mar 7, 2002 | 01:47 PM
J Z06's Avatar
J Z06
Thanks Bill... I'm up in the air also... thats why I am asking opinions. I like the way it feels now.
JP, you're right...it is a 99% Street Car. I guess I'll take your advice and leave it be. I don't think the trans failed(or didn't) because of heat. I WILL get the additional cooler in there however. I just spoke to my guy and he asked i make a few runs immedately after the re-build to make sure things are ok. Stickies are going on for that. It's staying at 2800 but being freshened. Thanks... I appreciate the input.
Old Mar 7, 2002 | 03:47 PM
GlockLT4's Avatar
GlockLT4
Leave it be ... :yesnod: :yesnod: And like said above, it will be different with different power. I believe with a 383 like ours a 2800 would stall a bit high. I left the 2400 stall in mine, mainly because of cost, but it should be a little better on the street too.
Old Mar 7, 2002 | 04:27 PM
J Z06's Avatar
J Z06
Default Re: Loosen it, or not? (Glock'94)
agreed glock. if it we're a weekend warrior...there'd prolly be a 3200 in there(take advantage of that low end torque) like beach bums(think his is a loose 3000). but it's not. i notified pro torque and they're going to give it the once over. it'll be down a little while..but that's alright.
jd
Old Mar 7, 2002 | 04:31 PM
GlockLT4's Avatar
GlockLT4
jd
Hopefully it won't be down too long .. like mine at least .. :crazy: :crazy:
Old Mar 7, 2002 | 09:05 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I agree with JP.
Old Mar 7, 2002 | 09:15 PM
J Z06's Avatar
J Z06
Default Re: Loosen it, or not? (Mr Mojo)
I agree with JP.
Me Too! :)
Old Mar 7, 2002 | 09:24 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
JD, stay with what you've got, thats seems fine for your combo and street use.
Do you have soneone to do the trans???????????????
If not Impala Joe could help you out.
Old Mar 7, 2002 | 09:42 PM
J Z06's Avatar
J Z06
Default Re: Loosen it, or not? (mackeyred96)
It's all set. My local guy who did this one(it lasted the longest of the three...two we're done by rossler, LPE's people and they lasted 4000 miles each, zero track runs...this one lasted 22,000 miles and hard street use). I spoke to Impala Joe about it, ironically I didn't think it'd need the attention this soon. Better now than in the summer. I could easily be ready for the challenge with the fixed intake gasket too.
Thanks Mack.
To Loosen it, or not?
