Tranny Cooler, do I need one?
Old Mar 7, 2002 | 01:43 PM
TIMSPEED's Avatar
TIMSPEED
Default Tranny Cooler, do I need one?
I'm going to be putting in a ProTorque 2400-2800 stall converter in my car, and I'm wondering if I should upgrade to an actual tranny cooler. I have the factory equipped one. (Brand new radiator, so the tranny cooler is brand new too), but I'm thinking, shoot, tranny coolers are around $50, I could easily afford it. Will it give me benefits, and do all I have to do, is just plug the lines into it, that go to the factory cooler? Thanks!
Old Mar 7, 2002 | 01:58 PM
dgoodhue's Avatar
dgoodhue
Default Re: Tranny Cooler, do I need one? (TIMSPEED)
Yes put a tranny cooler in! Heat is your tranny enemy and new torque converter will add more heat.
Old Mar 7, 2002 | 03:51 PM
GlockLT4's Avatar
GlockLT4
Default Re: Tranny Cooler, do I need one? (dgoodhue)
ABSOLUTELY! I'm putting one on mine and it's stock 2420 stall. You want that thing to be as cool as possible (within reason). Keep it below 200 and you're good to go.
Old Mar 7, 2002 | 08:17 PM
vader86's Avatar
vader86
Default Re: Tranny Cooler, do I need one? (Glock'94)
with the new TC, it would be a good idea to have one put in
Old Mar 7, 2002 | 08:24 PM
cprgmr's Avatar
cprgmr
Yep, you can use an aftermarket cooler in tandem with your stock cooler. I picked up a B&M Supercooler and the preferred method is to use them both at the same time. :) BTW - are you sure you don't want to get in on the Vigilante GP?
[Modified by cprgmr, 6:25 PM 3/7/2002]
Old Mar 7, 2002 | 08:32 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
A trans cooler is a must.
Old Mar 7, 2002 | 09:32 PM
red-y's Avatar
red-y
Yes - Just did it, good insurance to keep your temps down and extend the life of your transmission. :seeya
Old Mar 7, 2002 | 09:36 PM
jpee's Avatar
jpee
Default Re: Tranny Cooler, do I need one? (mackeyred96)
There are two types of coolers, the tube & fin type, & the "stacked plate type" the 2nd is what I have ..I've had both types & the stacked plate type is 100% better, since I went to the stacked plate, my trans temp has never gone over 185...
With my old one I hit 230 + on several occasions, another + is I was able to get it at a Carquest for about $70..
One of the Best things I've done..
Old Mar 7, 2002 | 09:44 PM
J Z06's Avatar
J Z06
Default Re: Tranny Cooler, do I need one? (Red96Coupe)
John P is on the $. His car, Ralphs and Mackey's all have a good cooler and they don't have much trouble with overheating. The stacked plate unit is finding it's way in my car once it's all back togehter(trans). I would follow His advice.
To Tranny Cooler, do I need one?
