Rattling rear view mirror
Old Mar 7, 2002 | 06:41 PM
GlobalGreg's Avatar
GlobalGreg
Default Rattling rear view mirror
My left rear view mirror rattles and shakes pretty bad...what is involved in replacing that? It's the kind that has the defroster in the rear view mirrors also, although I think all Vettes past a certain year have that. Thanks!
Old Mar 7, 2002 | 06:50 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Default Re: Rattling rear view mirror
Is it the whole thing, or just the glass? There is a replacement trunion from Ecklers. Hope this helps.
Old Mar 7, 2002 | 06:52 PM
JonM's Avatar
JonM
Default Re: Rattling rear view mirror (GlobalGreg)
If its the entire housing that is rattling ...take the panel off the inside and tighten the two bolts holding the mirror to the door. I think they are 10mm
Old Mar 7, 2002 | 06:58 PM
GlobalGreg's Avatar
GlobalGreg
Default Re: Rattling rear view mirror (GiDvEtTe84)
Sorry, I should of been more specific. It's just the mirror part, not the housing. Thanks, I'll check with Eckler's.
Old Mar 7, 2002 | 07:04 PM
GlobalGreg's Avatar
GlobalGreg
I found it... http://www.ecklers.com/product.asp?p...dept%5Fid=1482 So do I just pop out the mirror with a screwdriver or something flat and put this new trunion on?
Old Mar 7, 2002 | 07:10 PM
JonM's Avatar
JonM
The mirror just pulls out...it is somewhat delicate...wait till you get the new one so you will see what you have to do to work it out.
Old Mar 7, 2002 | 09:42 PM
Raysur's Avatar
Raysur
Default Re: Rattling rear view mirror (JonM)
Just take out the lenses. Just pop them out with a screwdriver and put silicone around them later. My '93 had a rattle in the mirror too. :cheers:
Old Mar 7, 2002 | 10:03 PM
Shylor's Avatar
Shylor
The mirror base of my side mirror is loose. How can I get inside it to tighten the bolts? Do I have to take off the inner door panel? Seems like way to much trouble.
To Rattling rear view mirror
