remove valve covers.
Old Mar 7, 2002 | 05:27 PM
devilfish's Avatar
devilfish
Default remove valve covers.
On the driver side no probleme. BUT on the passanger side!! The damn A/C compressor is in the way. Must I take off the A/C compressor?
Regards
Old Mar 7, 2002 | 06:39 PM
devilfish's Avatar
devilfish
Default Re: remove valve covers. (devilfish)
anyone done this without removing the A/C?
Old Mar 7, 2002 | 06:54 PM
JonM's Avatar
JonM
Its no big deal to remove the bolts for the AC compressor and just slide it out of your way...just don't remove any hoses
Old Mar 7, 2002 | 11:15 PM
ittlfly's Avatar
ittlfly
It's no big deal to remove the compressor....10 extra minutes or so.... :smash:
Old Mar 8, 2002 | 01:52 AM
Vic'89's Avatar
Vic'89
Remove the AC compressor, it will make the job much easier.
Vic
Old Mar 8, 2002 | 11:08 AM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
I removed my passenger side on my 85 without messing with the compressor.
Old Mar 8, 2002 | 12:19 PM
NUckINg FuTS's Avatar
NUckINg FuTS
My pass. side vavle cover came off with no problem. Didn't even have to touch the AC compressor. All that needed to be moved was the intake manifold coolant hose.
Old Mar 8, 2002 | 02:47 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I had to remove the 4 bolts and rear brace and slide the compressor out of the way. I also had to bend the filler pipe slightly.
On the left side I had to loosen the alt and move it slightly.
Old Mar 8, 2002 | 02:54 PM
Warlock's Avatar
Warlock
4 bolts that hold the bracket, 10mm I think. Its the EGR tube that kills me. I always break a bolt. :cuss
Old Mar 8, 2002 | 09:29 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: remove valve covers. (Warlock)
Yep,
Did this about 10 times before I got my valve covers to seal without leaks. Kinda a pain. The small bolts that hold the compressor to the bracket are a pain in the &*^. You can only move them about 1/10 of a turn each movement and they are about 10 ft long. I decided that if I had to do it again there was going to be two small holes drilled through the wheel well (plastic piece) that I could then put a socket through. I hate to say it, but better you than me! :smash:
Old Mar 8, 2002 | 10:17 PM
MagRed_04's Avatar
MagRed_04
Default Re: remove valve covers. (ski_dwn_it)
Yup, what they said!!! :smash:
JK
To remove valve covers.
