Injector spray
Old Feb 10, 2010 | 02:03 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default Injector spray
Interesting thought....
Recently, I read that the injector ports on our motors were deliberatetly angled to point at the wall of the head intake runner passage. IOW, instead of pointing say,,,directly down the runner, they're pointed at the wall on purpose.
The reason was to provide add'l atomization of the fuel -- thru the pressure of the gas stream hitting that wall. When I started to visualize this, I pictured the difference between a hard jet of water hitting a wall vs a fine mist. That mental image made me realize there must be a point where too much atomization is detrimental.
If you spray a fine mist on a wall, it won't have the power necessary to bounce of that wall. Most of it will "stick", bead up, and roll down the wall. By contrast, a hard jet will hit hard, bounce, and splatter into much smaller "pellets" of fuel.
Make sense? If so, it makes you wonder about the stream-type of injector vs ones that atomize better. Is one really much better than the other? Could it be that the one we'd expect to be better, might not be? After the gasoline jet hits that runner wall, it needs to rebound and stay in a spray -- mixed with the incoming air. If it "sticks" to the runner wall, it can't mix with the incoming air as effectively.
Last edited by GREGGPENN; Feb 10, 2010 at 02:05 PM. Reason: Added 2 more sentences for clarity.
Old Feb 10, 2010 | 02:37 PM
engle1147's Avatar
engle1147
That info has been out there for some time.
On "batch" or "bank" fire setups fuel just sets in the head for most of the ports until the valve opens and it gets sucked in....so I don't think that too much atomization is really an issue.
Old Feb 10, 2010 | 03:32 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
hey greg.. good question, but, that design is old school, the injectors they had when they designed these are basically antiques. Do you realize that a new style injector with the 4 holes like the ones you have will shoot a stream 30 feet at 4 bar input.. also realize that at full static with 58 psi input if you put your finger under it the nozzle pressure will cut your skin to the bone.. watch this!
we should make flame throwers
or electronic paint guns
Old Feb 10, 2010 | 03:38 PM
Aardwolf's Avatar
Aardwolf
This is about wet flow. Around a quarter of the fuel is on the walls until it gets past the intake valve, then it is mainly large droplets. It splats on the cyl wall and spreads. There is a lot of research in this, and it's why some combustion chambers are designed the way they are. AFR did some testing and make Hurricane Chambers. I haven't checked into it for a long time though.
Old Feb 10, 2010 | 03:45 PM
FICINJECTORS
Supporting Vendor
there is so much tech on this its ridiculous. Always a new way or a new idea.. Which one is right? I don't know and I don't believe anyone does. The best way and most efficient way to get fuel in a cylinder is GDI injection. (gasoline direct injection) Most of the next gen engines will have this type of injector.
Old Feb 10, 2010 | 03:48 PM
Aardwolf's Avatar
Aardwolf
With that laser ignition I was reading about? Pretty cool idea I thought. Lasers for plugs! They also double as a sensor to show what the combustion chamber is doing.
Old Feb 10, 2010 | 03:49 PM
JackDidley's Avatar
JackDidley
Makes me wonder what the spray looks like on my Bosch IIIs, running 70# FP.
To Injector spray
