I need Help fast
Old Mar 7, 2002 | 07:28 PM
ZRWANABE's Avatar
ZRWANABE
Cruise-In III Veteran
Default I need Help fast
I need a picture of a pass. side window switch pulled out with the wires still atached so i can see how the wires go on my car. some one cut the conector off my car then put spade conectors on the wire so i need to see what color wire goes in which spot.
Thank you
Old Mar 8, 2002 | 12:28 AM
ZRWANABE's Avatar
ZRWANABE
Default Re: I need Help fast (ZRWANABE)
TTT
Old Mar 8, 2002 | 01:04 AM
JonM's Avatar
JonM
I don't have a pic for you but I may be able to help...Look at the drivers side I will lay it out drivers side color/pass side color....Dark Brown/Tan Dark Blue/Light blue All four blacks are common gounds so it doesn't matter and the pink is a common Positive...Hope this helps
Old Mar 8, 2002 | 02:20 AM
ZRWANABE's Avatar
ZRWANABE
Default Re: I need Help fast (JonM)
I have figured out what the colors do but there are 6 prongs on the switch and i need to kow in what order from top to bottom do the colors go
Old Mar 8, 2002 | 08:56 AM
JonM's Avatar
JonM
Tan and brown wires are for up, dark and light blue are for down then you have your common ground (black) and your common power (pink)
Old Mar 8, 2002 | 10:18 AM
ZRWANABE's Avatar
ZRWANABE
where is up and down on the switch?
Old Mar 8, 2002 | 11:13 AM
ittlfly's Avatar
ittlfly
Use a test light and a 12v source for the power. Power to the bottom pin, test light to a pin other than ground, operate the switch "up" and see which pin is getting power.....and the reverse for the down pin....just one way of doing it without a wiring diagram.... :smash:
Old Mar 8, 2002 | 12:54 PM
JonM's Avatar
JonM
Push the switch forward..it goes up...push it back it goes down...It really doesn't matter which side is up and down...you can mount it either way in the shifter plate. Just twist the wires/switch around it you get it backwards. I just did mine last week, with automatic roll up and down.
To I need Help fast
