L98 .060 over?????
Old Feb 14, 2010 | 02:53 PM
88yellowvette's Avatar
88yellowvette
Default L98 .060 over?????
Can anyone tell me is it worth doing a .060 over on a 88 L98? I was going to do a 383 but I dont think the 4+3 transmission will handle it since I already blew it twice. I dont want to replace the transmission.
I have everything off the engine done to the block.
Was going to port the stock heads and new after market manifold and runners and install a 58mm throttle body.
Also I'm removing the air pump and all hoses. Do I need to keep the EGR pipe?
Need some advice Thanks,
Old Feb 14, 2010 | 03:18 PM
floridamale's Avatar
floridamale
Old Feb 14, 2010 | 03:37 PM
cumbercr's Avatar
cumbercr
Mine was bored .060 over. The previous owner was not big on spending money if he didn't have to.
Personally if I was looking at further mods down the road I would want a sound bottom end. A few hundred dollars more now could eliminate concerns later.
Old Feb 14, 2010 | 03:59 PM
88yellowvette
[QUOTE=cumbercr;1573097703]Mine was bored .060 over. The previous owner was not big on spending money if he didn't have to.
Personally if I was looking at further mods down the road I would want a sound bottom end. A few hundred dollars more now could eliminate concerns later.[/QUOTE
Is it a big power gain?
Old Feb 14, 2010 | 04:10 PM
VeTTeMaNC486's Avatar
VeTTeMaNC486
honestly, the only reason to overbore on a rebuild is to have round, clean cylinder walls. Only overbore enough to clean up the cylinder walls, in case you have to rebuild later on. If you do .060 and don't need that much to clean up the walls and if you ever have to rebuild you might be looking for another block.
Old Feb 14, 2010 | 04:13 PM
88yellowvette
Thanks for the info. My walls are perfect now. I only have 56,000 miles on the engine. So over boring wouldn't do me any good.
Old Feb 14, 2010 | 04:19 PM
VeTTeMaNC486
take it to a machine shop unless you have the tools to check for roundness. You could probably get by with a hone, but again I advise checking (either do it yourself or get a machine shop to do it)
FYI, when i tore down my 86 with 95k miles there was almost no wear in the cylinder, I did a .030 overbore just to be on the safe side, that leaves two more (.040 and .060) standard over bore sizes left if I ever rebuild.
Old Feb 14, 2010 | 05:04 PM
c-4 lhozwalte's Avatar
c-4 lhozwalte
over boring isnt good for enough hp by its self to be "worth it"
Old Feb 15, 2010 | 12:46 AM
Hot Rod Roy's Avatar
Hot Rod Roy
If you need to replace the pistons, you might as well go bigger! I went with a +.040 bore, which also give you a half point more compression ratio, at no additional charge. A .040 overbore gives you 357 cu. inches. I could definitely feel the difference. I'd recommend a balance job for a smooth running engine. If you need to build the engine again, you are definitely an incurable Corvettoholic! My original engine went 200,000 miles!
Old Feb 15, 2010 | 01:02 AM
Curveit's Avatar
Curveit
I agree with what some have posted above...bore jobs are to give you nice round Cylinders; remove scratches, etc. I'd go .010 over only if a Hone wont clean things up.This keeps thicker, stronger Bores/Block and leaves room for .020 & .030 down the road. I don't think .060 is advisable for modern SBC blocks; at least not without Sonic checking the Block first. Way back in the old days, you could bore some brands of motors 1/8" or more and that would show some power improvements.
Old Feb 15, 2010 | 08:33 AM
BLOCKMAN's Avatar
BLOCKMAN
If you are going togo .060 over have th cylinders sonic tested as we find very few that willl go .060 and have enough cylinder all to maintain a good ring seal.
Which ever way you go have it plate honed for good ring seal when the heads are bolted on.
Good luck with your build
Old Feb 15, 2010 | 11:33 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
If you have the engine out of the car, and are staring at 8 empty holes, a standard .030 overbore will clean things up, and there are thousands of piston sets ready to be had for cheap at the .030 oversize.
Put a cam in it that will maximize your engine's operating speeds, and you will enjoy it a hundred times more than you do now.
Use the cam out of a ramjet 350, and you will love it. the part number is 14097395, and it will give you more low end grunt, and tons of midrange, just where the TPI flows the best.
Maximize torque, and the HP numbers will fall where they may.
HP isn't what the TPI is all about.
This cam also comes in the hi-torque 383, and is a stump puller of a cam.
Old Feb 15, 2010 | 08:46 PM
Curveit's Avatar
Curveit
Again, why go .030 when the thing only has 56K miles on it. A Hone or if you were buying new Pistons for some reason (383-396-421), .010 would clean it up. Go .020 or .030 on the next rebuild. Hone Plate like Blockman said; it costs very little extra.
That #14097395 Cam is actually a Truck Cam ( 196/206) and is smaller than the stock L98.
Old Feb 15, 2010 | 10:50 PM
Pwnage1337's Avatar
Pwnage1337
Stroke will bring much larger gains than bore
To L98 .060 over?????
