Cam/Distributor gear
Old Feb 15, 2010 | 08:41 PM
Redvette_22's Avatar
Redvette_22
Default Cam/Distributor gear
I had planned on installing a Comp Cams camshaft into my 89 Vette but....
I have both called their tech dept and sent emails and even with the information they grudgingly gave me, they never mentioned that I could have a need to change the distributor gear. I've been told from other sources that it could go either way...has anybody done a swap like this? What was the end result of the distributor gear you used?
Old Feb 15, 2010 | 08:58 PM
427c4vette's Avatar
427c4vette
http://www.cpgnation.com/forum/prope...haft-2519.html
Your 89 has a roller camshaft so you have a melonized gear.
Old Feb 15, 2010 | 09:04 PM
WW7's Avatar
WW7
With the engine that Pete K is building for me we will have a cast Erson roller cam installed, when I called Erson cams to ask about which gear to use this is what Mr Erson told me..With a cast cam you have to use a cast iron distributor gear . With a billet steel cam you have to use a bronze distributor gear. Now, some manufactors that make steel cams still use a cast iron gear on the cam that is pressed onto the end so you can use a cast iron distributor gear instead of a bronze gear..And last but not least if you want a distributor gear that will work with any cam made, you can get a composit distributor gear for about $100.00.. My suggestion would be to contact the cam manufactor to see which gear to get for your distributor because for me , it was very confusing..WW
Old Feb 15, 2010 | 09:13 PM
Pete K's Avatar
Pete K
Wayne is spot on. I have run many comp steel cams with pressed on iron gears. Don't be afraid to run one, if you are not running a cast iron cam.
Old Feb 15, 2010 | 09:27 PM
Redvette_22
How do I determine if I have a melonized gear on the used distributor that I purchased? It's supposed to be from a late model Camaro with a number of 1103880 but I can't confirm that. I'm changing from a large cap to a small cap distributor.
Old Feb 15, 2010 | 10:01 PM
WW7's Avatar
WW7
It will be hard to tell which gear you have on your distributor unless someone can tell you for sure which cam they were running..Its not a good idea to reuse a distributor gear on a new cam anyway because of the wear pattern you would have on the old gear.. Distributor gears aren't expensive anyhow unless you go for the composit gears..I think the cast distributor gear for my cam was $27.00. A melonized gear is just a cast iron gear with a hard coating according to the product sites.....WW
Old Feb 15, 2010 | 11:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm considering a Comp Cams cam for my current L98 rebuild and see that they do offer that composite dist. gear.
Though I'd rather have a cam with a cast iron gear to use stock dist gear, I may try the CC anyway.
Anyone have any experience on the expected life of the CC composite dist. gear??
Old Feb 16, 2010 | 09:14 AM
WW7's Avatar
WW7
From what I have read the composite gears have very low wear and are compatable with all cam metels, there only drawback it the price.( $100.00).Cast iron gears are from $27.00 to $50.00...WW
Old Feb 16, 2010 | 07:54 PM
65Z01's Avatar
65Z01
I heard that GM dist came with a hardened steel gear for compatability with the '87 & later roller cams.
Shouldn't this make a CC cam comatable with the OEM dist gear??
Still I'm thinking that, after ~200k miles, I should install a new dist gear during this rebuild??
To Cam/Distributor gear
