Problems with the chime module
Old Mar 8, 2002 | 10:51 AM
Lichen_1's Avatar
Lichen_1
Default Problems with the chime module
My chime module acts like it has a loose connection to it, will someone enlighten me as to where this module is located.
Old Mar 8, 2002 | 10:58 AM
bwagner's Avatar
bwagner
Default Re: Problems with the chime module (Lichen_1)
Are you talking about the chime when you open the door? Mine is doing the same thing, it sounded like it's sick then finally just went out.
Old Mar 8, 2002 | 11:04 AM
Lichen_1's Avatar
Lichen_1
Default Re: Problems with the chime module (bwagner)
Yup I am talking about the door/seatbelt chime module. I wish that I had the Corvette Service Manual Book #2 so that I could find it, but I only have book #1. Mine will chime irratically/intermitantly as if a wire is just barely hanging on to it. Sometimes it doesn't work at all. I have to tear into my dash to fix the start enable relay so I figured since the dash is already torn apart I might as well knock out two birds with one stone if they are located anywhere near each other. Right now the chime is not working at all so I couldn't just listen for it while the dash is appart to find it.
Old Mar 8, 2002 | 11:08 AM
bwagner's Avatar
bwagner
Yeah, mines totally out now. So it's to a point now that I don't even remember it.
By the way, I use to live in Gainesville, awesome place when school is in. My brother still lives there, He works at Stripes Motor Sports....
Old Mar 8, 2002 | 11:12 AM
Lichen_1's Avatar
Lichen_1
If mine would just totally die, that would be fine too then I would forget about it; but it won't lol it just drives me nuts by working part of the time and sounding funny. Yeah I graduated here in electrical engineering and found a related job here. By the way I like your picture from the moon! One of these days I will get a sig picture but I am a nubie here. I have had my corvette for about 2 months now as a second car and looooove it.
Old Mar 8, 2002 | 11:19 AM
bwagner's Avatar
bwagner
You should be able to still put up a sig, just register for the home page under the Home Pages tab. This will allow you to upload pictures to use for a sig.
Yeah, I just edit a picture of my car and pasted it to this picture of earth I found. I thought it turned out pretty :cool: This is my second vette. I had a 88 35th Anniversary was my first one. So I've had vettes for about the last 6 years and I love it too! It's something that gets you hooked.
Old Mar 8, 2002 | 12:25 PM
2funnn's Avatar
2funnn
My 92 is doing the same thing but I cant find it. It sound kinda sick or like
it in slow motion. :flag
Old Mar 8, 2002 | 12:51 PM
Goody's Avatar
Goody
Default Re: Problems with the chime module (2funnn)
Dang, must be contagious.......I got it too!! :eek: :D :seeya
Old Mar 8, 2002 | 01:06 PM
JonM's Avatar
JonM
Default Re: Problems with the chime module (Goody)
I am working on mine at this very moment...Mine is behind the multiuse panel above the radio. In mine its a blue box the size of an index card on the right. I would suspect yours is there also.
Old Mar 8, 2002 | 01:19 PM
bwagner's Avatar
bwagner
Default Re: Problems with the chime module (JonM)
Is this what makes the chime?
Old Mar 8, 2002 | 02:47 PM
JonM's Avatar
JonM
Its all part of a sequence of events...There are four wires running from the chime buzzer which makes your bells and whistles (blue box, yours may be different) The pink wire/black stripe is power, you have one continuious black ground from the buzzer. the yellow wire runs to the Idiot light (pin 18) and a black wire coming out of the idiot light (pin 2) to seat belt. You also have a + black wire running from the chime to the seatbelt. So fix it and ring a ding ding
Old Mar 8, 2002 | 09:01 PM
Black 'n Blue's Avatar
Black 'n Blue
'90 and up have a different dash assembly. Things may be moved around a bit.
To Problems with the chime module
